Front end wobble
Old Jul 27, 2013 | 10:24 AM
coolflames's Avatar
coolflames
Default Front end wobble
After rebuilding my front end on my fxst the new fork seals were leaking. It rode fine but they leaked. The harley tech said try and take out 2 oz fork oil. Then it developed a front end wable. So i put the 2oz back in still have the wable. New tire, new tube, new fork tubes,seals, tire balanced with ceramic beads. Wheel does not appear to be bent. Any thoughts. Could use any help you might have. Thanks, russ
Old Jul 27, 2013 | 10:41 AM
Juan L's Avatar
Juan L
Moderator
Remove front wheel, loosen fork pinch bolts, reinstall wheel, lightly tighten axle, tighten fork pinch bolts, torque wheel.
Old Jul 27, 2013 | 10:53 AM
Bone Doc's Avatar
Bone Doc
If you have laced wheels, check for loose spokes (front and rear)
Old Jul 27, 2013 | 11:44 AM
oldairboater's Avatar
oldairboater
Both good suggestions above. Eliminate that wobble.
Old Jul 27, 2013 | 02:26 PM
coolflames's Avatar
coolflames
Default wobble
well i did as you said and i tightened up the steering head a little. got rid of the slow speed wobble. but once i get up to 40mph its back. should i try to tighten the steering head more?
Old Jul 27, 2013 | 02:51 PM
steamybob's Avatar
steamybob
Check the spokes - my front end wobble was caused by loose rear spokes.
Old Jul 27, 2013 | 03:07 PM
schumacher's Avatar
schumacher
out of curiosity, what brand tire did you put on it?
Old Jul 27, 2013 | 06:21 PM
coolflames's Avatar
coolflames
dunlop same as came on the bike. but wobble started after draining and refilling the fluid. and reused the same fluid. it only had 200 miles on it.
Old Jul 27, 2013 | 07:01 PM
Def Mute's Avatar
Def Mute
Since you reused the same oil...
Did you add any to be sure it was filled to spec? Low oil might possibly be the cause for your wobble.
Old Jul 27, 2013 | 07:30 PM
BLKPRLFLHTCU's Avatar
BLKPRLFLHTCU
Probably has nothing to do with the fork oil, do what the first reply to this thread said to do... don't force anything forks should slide in the trees easy with a little oil on them, axle should go through the lowers and turn easy before you tighten anything up.
