Fix a flat or not?
Old Aug 25, 2013 | 05:15 PM
08loryder's Avatar
08loryder
6th Gear
Originally Posted by Jonesee
Run it and forget it.
I've run patched or plugged tires for thousands of miles at highway speeds for hours on end and never worried about it.
Repaired or not, I run my tires until the tread is gone.
There will be a group sign on here in a bit that will tell you that you are sure to have a catastrophic failure and face imminent death.
If you decide to replace the tire and it will fit my Dyna, send it to me rather than throw it away and I will pay the postage. Serious offer.
Thanks for the info and the warning. I'm gonna run with it.
Old Aug 25, 2013 | 05:17 PM
08loryder's Avatar
08loryder
6th Gear
Originally Posted by HD7585
If the puncture is bigger than a pinhole.....you need to patch it on the inside so the cut won't pinch your new tube as the tire flexes
Thanks
Old Aug 25, 2013 | 05:19 PM
08loryder's Avatar
08loryder
6th Gear
Originally Posted by kraydog
Had a small nail in a tire with a tube on a softail with spoke wheels.tire only had 3,000 miles so I put in a new tube.Now the tire has over 15,000 miles and needs replacing,but I was good to go for a lot of extra miles.
Thanks kraydog!
Old Aug 25, 2013 | 05:21 PM
08loryder's Avatar
08loryder
6th Gear
Run it , isn't rocket science . What do you think we did 30 plus years ago out in the middle of Busted Nuts nowhere when you got a flat ? And nobody I know ever crashed or died from it .......................
Thanks TwiZted
Old Aug 28, 2013 | 08:44 AM
stmcmann's Avatar
stmcmann
I currently have a Michelin Commander II with over 10,000 miles on it and over half the tread still on it on y 08 E.G.C. when one day during clean up I noticed it had a metal clip of some kind that had punctured the tread right in the center. I pulled that out, installed a plug, and have been riding it now for over 1,000 miles with no issues, and it doesn't leak air around the plug! Just do it and ride!
Old Aug 28, 2013 | 09:22 AM
jdw999's Avatar
jdw999
Here's my take on it...
The reason nobody has said that you should replace the tire is because they are all out of commission or dead from riding on patched / plugged tires and are not able to respond to this post. This should serve as a warning for us all, you will DIE in three days if you don't replace that tire and send this message to 28 people within 24 hours.
JD
Oh yeah, in case you cannot tell, that was sarcasm...
Old Aug 28, 2013 | 09:36 AM
Pondskipper's Avatar
Pondskipper
Now where does that gas cap go again?
dave713
Dec 28, 2015 12:56 PM
1radtoy
Aug 6, 2015 05:55 AM
Streetrunner
Mar 5, 2012 04:59 PM
maineultraclassic
Jul 25, 2007 01:19 PM
rejlaw
May 6, 2007 05:12 AM
