Engine Light
Old Aug 25, 2013 | 05:04 PM
Boriken61's Avatar
Boriken61
Stage I
Unhappy Engine Light
I have a 2003 Road King Classic 100th Anniversary. After I start the bike, the engine light comes on momentarily and then goes out. Anyone knows what's causing that? How can I take care of it?
Thanks!!!
Old Aug 25, 2013 | 05:31 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
Removed ....erroneous information.
Old Aug 25, 2013 | 05:49 PM
bdtaylor1979's Avatar
bdtaylor1979
Does it come on when you turn the key on and then turn off about 6 seconds later or is it off when you start it, then comes on and goes back off? If it comes on when you turn the key on and goes out about 6 seconds later and doesn't come back on, its supposed to do that.
Old Aug 25, 2013 | 06:21 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Mine does what bdtayor said. And I asked the same question, why/what was it doing. I was told the computer is checking the engine specs. As long as it comes on and then goes off, I'm okay.
Old Aug 25, 2013 | 09:21 PM
pavin's Avatar
pavin
I had a engine light that kept comming on intermittently when driving. Ended up being a loose spark plug wire.
Old Aug 26, 2013 | 04:41 AM
oldairboater's Avatar
oldairboater
Light should come on as the bike goes through it's checks. If your one of those people that flips the key switch on then hits the starter button immediately. Your beating the ecm through the checks. If you wait and the light cycles in then out before starting. It is doing it's stuff.
Old Aug 26, 2013 | 07:01 AM
Def Mute's Avatar
Def Mute
Engine light comes on when you turn the ignition switch to on position. Then once the engine is started, it stays on for 4 seconds, then goes out. If after another few seconds it comes back on, and stays lit for about 4 seconds, that is the indicator telling the operator that there may be a diagnostic trouble code present.
It may be an historic code, meaning that it had a problem that no longer exists, but is still in memory. Or, it could be a present code with an existing problem. If it is an historic code, the light will cease showing after 50 on/off cycles.
GET A FUGGIN MANUAL!!
(and read it!)
mikeferns
May 2, 2018 07:45 PM
XMA
May 27, 2013 07:54 PM
georgemt54
Oil Archive (no new posts)
Sep 13, 2012 08:15 PM
Cabose
Jun 13, 2012 09:18 AM
FastPitchFan
Jun 4, 2008 09:19 PM
