Did I make a jacking mistake???
Old Mar 6, 2007 | 11:09 PM
jr_c6's Avatar
jr_c6
Default Did I make a jacking mistake???
I used my jack today for the first time on my Deluxe. To get it to balance correctly, I realized it was under the shocks. It was on the jack for maybe 5 minutes. Did I do any damage and how would I know?
Thanks for the help.
Old Mar 6, 2007 | 11:12 PM
mopardave's Avatar
mopardave
Default RE: Did I make a jacking mistake???
Those shocks are very beefy and rubber mounted. I doubt you hurt them, but I always have avoided that. If they got bent, you would know I would think. It probably wouldn't let the rear suspension move correctly and they might leak. Good Luck.
Old Mar 6, 2007 | 11:16 PM
Turbo Flux's Avatar
Turbo Flux
Even though the shocks are there, I think the frame rails are lower than the outer diameter of the shocks. If you can't see any damage (dents) in the shocks, I'm sure they are fine.
Old Mar 6, 2007 | 11:36 PM
chopperz71's Avatar
chopperz71
I just hate it when I make a jacking mistake. It's a good thing you got the jack-off the bike when you did.
Old Mar 6, 2007 | 11:37 PM
mopardave's Avatar
mopardave
Nope, the shocks are actually sticking down a little bit lower than the frame rails.
Old Mar 7, 2007 | 12:00 AM
jr_c6's Avatar
jr_c6
ORIGINAL: chopperz71
Just hope I didn't bust a... well, you know... [8D]
Old Mar 7, 2007 | 05:02 AM
PWHOG's Avatar
PWHOG
I use the HD Orange Rubber strips that allow the bike to be jacked up on the frame rather than the shocks
Frame Protectors
Use these Frame Protectors to protect the underside of your motorcycle when using any lift. A must for SoftailÂŽ models to provide the clearance necessary to keep lift pressure on the frame and not the shock absorbers. Universal and customizable to fit any V-Twin Harley-DavidsonÂŽ motorcycle.
94675-99
Fits all 1-1/4" frame tubes. (pair)
MSRP US $15.95
[IMG]local://upfiles/3771/729D6F4D968B49D1954DF199A454C072.jpg[/IMG]
Old Mar 7, 2007 | 07:39 AM
Roses's Avatar
Roses
all of this talk is fine and dandy. However, I have one question. Aren't the shocks designed to hold up the wieght of the entire motorcycle? Duuuuhhhh!!!! Of course I forget that the shocks on these softails are horizontal!!!??? Yes I would worry about it, lose sleep over it, and fret over it until it ruins my week. Then I would look to see it there was any damage.
Old Mar 7, 2007 | 09:21 AM
Bubba Zanetti's Avatar
Bubba Zanetti
ORIGINAL: jr_c6
I hope there was no fluid spurting out after you jacked it.[sm=yikesomg.gif]
Old Mar 7, 2007 | 12:54 PM
CHEESE's Avatar
CHEESE
I made a jacking mistake once, used Ben-Gay, OUCH!
