Manual compression release question
Old Sep 25, 2013 | 12:28 PM
128auto's Avatar
128auto
Exclamation Manual compression release question
Ready to build my 107 in a few weeks, also putting a set of compression release. What brand do you recommend? Does it really matter? I see some of them have plastic caps, are they going to melt? Thanks! Alex
http://www.ebay.com/itm/TP-Engineeri...2d3110&vxp=mtr
Old Sep 25, 2013 | 12:46 PM
QSHOG's Avatar
QSHOG
Mine have plastic caps and have not melted. I'm not sure what brand they are.
Old Sep 25, 2013 | 01:07 PM
sobluemf's Avatar
sobluemf
Nope they will not melt. Any brand will work fine. It is a little learning curve using them. You have to remember to open them every, and I mean every time before you try and start the bike. Failure to do so will wear out your starter and quick.
I had the manual releases on my 110 and was about to switch them to the automatic but someone wanted to buy the bike as it was.
Old Sep 25, 2013 | 01:24 PM
128auto's Avatar
128auto
Does it mean the one with plastic cap is more practical when engine is hot? Fried fingers!
Old Sep 25, 2013 | 02:05 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
You're not going to grab them, you're just going to push them down, quick. I've never been burned by mine.
Old Sep 25, 2013 | 03:36 PM
128auto's Avatar
128auto
Push down start, pop up automatically if I got that right.
Thank you!
Old Sep 25, 2013 | 04:46 PM
Boilermaker219's Avatar
Boilermaker219
I have the plastic caps. They will not melt. You'll definitely notice how much easier it is on the starter when you install and use them prior to starting.
Old Sep 25, 2013 | 07:33 PM
dyna rider's Avatar
dyna rider
Default Compression Releases
Those EBay releases are a lot better looking than the HD ones and half the price.
I've had mine on the bike for about 4 years now without problems. Once in a while one of them will hang in the open position when the motor is hot and I start it. I just rev the motor a bit and it will close. I obviously need to pull them out and lube them up.
I don't usually forget to open them when I start the bike but if I do the starter really drags turning over the motor.
The plastic caps won't melt.
Old Sep 25, 2013 | 11:57 PM
sharkey's Avatar
sharkey
Had 2 sets of the HD ones; they had a tendency to pop closed as soon as the motor started to turn, so I took one apart...they use a circular spring clip on the outside of three detent *****; the spring clip can rotate and one of the ball bearings will hang up in the gap, leaving only two to hold it "in" ... I know what this must sound like to SOME of you, but anyway, I went with aftermarket releases (Headquarters supplied) for the same thread and they worked fine.
BTW; on my next build this winter I'm going to use S&S E-Z start cams...similar technology has been around on Yamaha's and V-Rods for years...
Old Sep 26, 2013 | 08:59 AM
Reindeer's Avatar
Reindeer
Get in the habit of engaging them every time. I don't even think about it anymore, just turn the ignition, hit the MCRs, press start button.
The plastic capped ones are probably a good idea. The metal ones get hot pretty fast.
IzzoQuazzo
Aug 7, 2012 08:51 PM
cptdenny
Aug 30, 2010 11:21 PM
Benito
Jun 4, 2010 07:57 AM
jackinthebox
Exhaust System Topics
May 5, 2010 02:39 PM
jackinthebox
Feb 15, 2010 08:40 AM
