need help diagnosing noise
Old Oct 1, 2013 | 05:53 PM
simpkinst's Avatar
simpkinst
Default need help diagnosing noise
Leaving for work this morning, turn onto the main road and start going. Hear a noise when upshifting. Turned around and parked it.
Got home and gave it the once over. No noise when shifting up or down while stationary.
No noise when clutch is engaged.
Took it for a spin and noise is still there. Only hear it when upshifting. Does not happen while downshifting. Does not happen when the clutch is engaged at any speed.
Only when my foot is on the shifter and the gear is changed up is this noise heard. And it only seems to happen when cold. After riding 15 min or so it goes away.
Checked all fluid levels and all is well. Clutch is adjusted per manual.
This is a high pitched squeal type of a sound, not "mechanical" sounding at all like grinding gears.
2006 FLHX - 5 speed.
Any ideas will be appreciated.
Old Oct 1, 2013 | 06:26 PM
RHillbilly's Avatar
RHillbilly
Is your belt too tight could be a bearing going out
Old Oct 1, 2013 | 06:29 PM
kenporider's Avatar
kenporider
6th Gear
Sounds like it might be the shift linkage.
Old Oct 1, 2013 | 06:40 PM
simpkinst's Avatar
simpkinst
I replaced the linkage early last summer, don't think this is it. Would expect same noise whether shifting up or down......
Old Oct 1, 2013 | 06:42 PM
simpkinst's Avatar
simpkinst
hmmmm. Not sure why the belt would be tight - haven't messed with it. Something to check though....thanks for the suggestion. Added to the list for tomorrow.
Old Oct 1, 2013 | 09:23 PM
RHPAW's Avatar
RHPAW
There's a gerbil stuck in your shift linkage. When you upshift, it hits him right in the nuts. That's the high-pitched squeal you hear.
Oh...and his name is Ragget.
Old Oct 2, 2013 | 06:51 PM
simpkinst's Avatar
simpkinst
No other ideas here?????
Old Oct 2, 2013 | 07:34 PM
dv102's Avatar
dv102
On occasion my bike will have a squeal chirping sound on cool mornings when I start out and after a few minutes it will quiet down. I figured it was the belt being cooler. But this only happens on cooler mornings. If the temps are around 60 and above never hear it.
beaucipher
Aug 2, 2014 12:07 PM
TUCCI
Mar 26, 2013 11:36 AM
dad311
May 21, 2011 10:46 PM
jefnightrain
Jun 11, 2009 06:52 PM
HardyHarHarley
May 17, 2009 10:53 PM
