Powdering triple trees question
Old Oct 12, 2013 | 02:56 PM
MattFXDB's Avatar
MattFXDB
Default Powdering triple trees question
I'm getting some parts together to get powder coated and have a question about the trees.
Is the fork stem permanently attached to the lower fork brace, or is it pressed in place with a plastic bearing?
Provided that the stem is masked off is there any reason to remove the stem from the brace?
Also, does the inside of the clamping area need to be masked off, or is it ok to powder the inside of that area.
Thanks
Old Oct 12, 2013 | 04:28 PM
Crazy's Avatar
Crazy
I've had the trees powdercoated on three different bikes. Leave the stem on and mask it. The inside of the clamping area needs to be masked, or you need to grind/sand the powdercoating out of there, or the forks won't fit.
Old Oct 12, 2013 | 04:32 PM
TwiZted Biker's Avatar
TwiZted Biker
Don't touch the stem and be sure you clean the clamping to bare metal area after coating if it isn't taped off correctly . Razor blade works well for this .
Old Oct 12, 2013 | 04:44 PM
Crazy's Avatar
Crazy
Nice. I never thought of that.
TUFF LUCK
Sep 12, 2018 04:38 AM
Schmidt0221
Jun 18, 2017 10:43 PM
slvrscoobie
Jan 8, 2017 11:16 AM
apetterez
Apr 15, 2015 02:43 PM
MAX EVO
Oct 4, 2006 08:23 AM
