Delaware Memorial Bridge
Old Mar 12, 2007 | 11:49 AM
CroftonDamico's Avatar
CroftonDamico
Default Delaware Memorial Bridge
Being a "novice" and crossing the bridge with my 4x4 the winds sometimes are very high. In April I am heading up to South Jersey with my 07 UC, what lane would you recommend using on the North & South Side? Or would you continue into Phila and cross one of the smaller bridges. Can't recall if all lanes are concrete or corrugated steel.
Thanks
Old Mar 12, 2007 | 12:16 PM
Blue SOG's Avatar
Blue SOG
Default RE: Delaware Memorial Bridge
I cross that bridge all the time. I find the lane with the fastest moving traffic and use it. High winds are somtimes a factor but I just plug on ahead... maybe I'm use to it.
Old Mar 12, 2007 | 12:31 PM
EasternSP's Avatar
EasternSP
If I remember right, most of the time the speed limit on the bridge is about 35 or 45. Unless there is a strong storm coming in, you shouldn't have much trouble crossing it on your UC. I don't recall a grating surface on the bridge and the web sight about the bridge doesn't mention anything about grating.
Old Mar 12, 2007 | 12:47 PM
DenimStreet's Avatar
DenimStreet
If you don't have a fatboy with a solid front wheel, you should barely feel the wind. I always found that the solid wheel caught the wind and made the bike sway.
Old Mar 12, 2007 | 12:51 PM
scott4911's Avatar
scott4911
I think some of that bridge is steel grate. if you're running a 21" up front you might want to watch it.. If you're only doing 35 the wind shouldn't be a problem...
Old Mar 12, 2007 | 02:15 PM
CroftonDamico
Thanks for the info..... In April I will give it a go.. Do any of youuse EZ-Pass on the bridge and if so where do you haveyour transponder installed?
Old Mar 12, 2007 | 05:47 PM
Blue SOG's Avatar
Blue SOG
I use ezpass and it's mounted on the underside of the fairing (above the radio). I don't recall any grating on the DelMem andI've NEVER went 35 mph on this bridge. More like 55-75. Then again, I cross the Walt Whitman everyday at 55-75 too... [&:]Life's too short to go so slow!
Old Mar 12, 2007 | 06:00 PM
FBoy06's Avatar
FBoy06
There is no grating on the bridge and crossing it, even with a Fatboy is no big deal. In heavy wind all bikes get moved around. There are brackets for your easy pass that mount to your mirror. No toll going into Jersey, only coming back.
Old Mar 12, 2007 | 06:19 PM
89FLHT's Avatar
89FLHT
Crossed it many times last summer, you'll be fine.
Old Mar 12, 2007 | 10:57 PM
airjoe's Avatar
airjoe
I don't like big bridges even in a car.
