Starting Problem
Old Dec 8, 2013 | 02:22 PM
Maro9658's Avatar
Maro9658
Stage II
Default Starting Problem
Just bought a used, but nice, 1996 FXSTC. When it is cold it does not want to start. You can shoot starter fluid in and it will start, but when it does, it wants to backfire and it will idle rough for a few minutes. Once warm, seems to be fine. HATE starting fluid. Can't be good to use it constantly. Where should I start. I ordered a new battery, didn't know if this could cause the problem or not, due to not enough spark. Could it be the plugs, not firing good? Thanks Mike
Old Dec 8, 2013 | 02:40 PM
HDmikie's Avatar
HDmikie
Start simple first. Pull the plugs and look for fouling. Btw, wouldn't hurt to introduce yourself in the New Member area.
Old Dec 8, 2013 | 02:50 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If it's carbed , are you using the enrichener **** just above the horn on the left side? Push that **** once the engine warms up or you will foul the plugs.
Old Dec 8, 2013 | 10:35 PM
Fishrrman's Avatar
Fishrrman
To add to what seniorsuperglide mentioned in the post above, check out the enrichener **** and cable. Sometimes the **** "slides back in" when you pull it out (it can be adjusted to stay out, but you have to do it the right way). Or... the cable itself may be stretched or not properly activating what it's supposed to at the carb end.
Old Dec 8, 2013 | 11:16 PM
bdtaylor1979's Avatar
bdtaylor1979
Does it have aftermarket exhaust or an aftermarket air intake? If so and if the jets in the carb are stock, it could need a carb rejet. Or, if it has sat for a long time, the carb or fuel lines could be dirty/gummed up.
Old Dec 8, 2013 | 11:30 PM
bikenut1957's Avatar
bikenut1957
Try this - pull the enricher **** all the way out (make sure it stays all the way out). Give the throttle 3 good twists. Hit the starter button with one hand and work the throttle with the other. When she starts, grab the enriched **** and adjust accordingly.
Hope this helps.
Old Dec 9, 2013 | 08:59 AM
Ratbike_Mike's Avatar
Ratbike_Mike
Carbs sometimes need to be adjusted slightly for cold weather operation. That may be why you need the starter fluid. It's running a little lean. Try to richen the air/fuel mixture up (just a little bit more fuel) to see if that helps before you start tearing into everything.
Old Dec 9, 2013 | 09:13 PM
Maro9658's Avatar
Maro9658
Stage II
Thanks to all of you. It gives me a place to start and try. By the way I'm a 62 year old Vietnam vet that is pretty much a recluse, so you allowing me ask for your help anonymously helps out. Thanks
Old Dec 9, 2013 | 10:24 PM
oldairboater's Avatar
oldairboater
My latest and greatest method to start my 98 carbed Wideglide. Open fuel ****. Count to three. Turn on key ---wait till needles settle. Flip the run switch to run. Three good twist of the wick. Pull out the enrichener ****. Pull in clutch and hit starter button. Engine either catches or doesn't fairly quickly. Let off starter button if it doesn't catch. Twist wick twice more. Check to make sure enrichener **** is still all the way pulled out. Pull in clutch---hit starter. Engine always catches second time. Ease clutch out and hold enrichner **** out for a few minutes. Push enrichener **** in and get ready to ride.
Old Dec 10, 2013 | 09:11 AM
Geezr Glidr's Avatar
Geezr Glidr
Don't worry about the New Members area! I'm not on here either, to make all kinds of new friends! OK to just ask questions, or make comments. (Also, thanks for your service.)
whitbyrudie
Ironhead
Mar 22, 2014 07:29 AM
adwalker67
Jan 13, 2013 10:47 AM
Pinetop
EVO
Nov 16, 2012 10:01 AM
TGB
Mar 11, 2012 07:45 PM
JonV
Sep 29, 2011 07:03 AM
