base gaskets
Old Dec 27, 2013 | 02:44 AM
T's Toker's Avatar
T's Toker
Default base gaskets
i have a 2013 heritage and today I noticed about a half inch of seepage on both sides of the base gaskets.the bike only has 2600 miles on her.what would cause this?what should I do?and will it hurt to ride it or breaking in the motor? thanks
Old Dec 27, 2013 | 05:46 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
If you're talking about the joint between the jug and block, it should not be a problem.
Most likely during assembly, a bit too much oil got on the gasket (IIRC, an o-ring) and simply worked its way out.
Just keep an eye on it, clean with mild soapy water once in a while, and ride it. It may take quite some time for it to completely evaporate.
FWIW, this topic comes up fairly often so you should be able to find past threads on the issue.
Old Dec 27, 2013 | 05:54 AM
tcarille's Avatar
tcarille
Probably what he said.
Old Dec 27, 2013 | 07:34 AM
hardheaded's Avatar
hardheaded
yep!
Old Dec 27, 2013 | 09:50 AM
AlanStansbery's Avatar
AlanStansbery
Clean it up real good, as suggested, and see if it's still seeping now...
I'd think after 2600 miles, all the seating should have been done, and all the 'lube' 'worked out' of the joint between the o-rings and the jugs/case. That's quite a few heat cycles. My thought is based on limited experience, though. (I built a TC88 some years ago using S&S cases, and for the first 100 miles or so, I got some seeping as you describe. But after that, the area was dry).
I've got a new 2014, and it has not seeped in this manner at all (that I'm able to discern).
The other guys are probably right, it's nothing…but if it's definitely still seeping, I'd take it by the dealer to at least make them aware of the issue, and to go down on the record for having notified them of the seepage.
Alan
Old Dec 27, 2013 | 09:53 AM
Uncle Larry's Avatar
Uncle Larry
Alan
I'd take it by the dealer to at least make them aware of the issue, and to go down on the record for having notified them of the seepage. ... and get it in recorded on a work order.
Old Dec 27, 2013 | 09:59 AM
Markymannn's Avatar
Markymannn
Not to mention isn't it under warranty?
Old Dec 27, 2013 | 10:00 AM
qtrracer's Avatar
qtrracer
No base gaskets on your bike. O-rings. Mine weeped for a very long time, left the oil sweat marks on the case for probably 6 months. Then once all the excess oil weeped out, it stopped. Don't bother with making a special trip into the dealer to have it documented. Just wait till you take it in for the next service, heck most likely it will have stopped by then.
Hogpro's Avatar
Hogpro
Former Sponsor
It is probably assembly lube, not oil. Lots of threads on this if you do a search.
Old Dec 27, 2013 | 12:44 PM
oct1949's Avatar
oct1949
There's been several members reporting the same issue.
I believe all of them I read reported that after cleaning the cases the issue went away.
just keep an eye on it and as Uncle Larry said above it wouldn't hurt to at least let your service make note of it.
Harleypilot63
EVO
Jul 3, 2017 04:03 PM
TheBanditColorado
EVO
21
Oct 22, 2013 01:26 PM
AnyRoad
May 4, 2009 07:03 PM
BiggestDawg
Feb 25, 2008 04:41 PM
williams3803
Exhaust System Topics
Aug 28, 2007 12:42 PM
