Gerbing question
Old Aug 31, 2005 | 11:58 PM
steveokla's Avatar
steveokla
Default Gerbing question
For those that have the Gerbing heated clothing. Did you run a direct hookup to the battery, plug into the cig lighter? etc... If you hook up the battery, how did you run the connection???
Old Sep 1, 2005 | 12:12 AM
mikeisglidn's Avatar
mikeisglidn
Default RE: Gerbing question
if your tim the tool man you may consider the coil wire!!
Old Sep 1, 2005 | 12:34 AM
Toytech's Avatar
Toytech
Wire direct to the battery. That way you could use the plug in to maintain the battery over the non riding season. Direct to the battery makes it so the ignition does not need to be on to work. The negative of that is you can suck the battery dry if you don't remember to unplug or turn off your heat.
I ran mine under the seat nytied to the frame rail then attached with more nyties to the passenger grab rail on the left side where the Gerbing gear has the clothing plug in. Tidy and simple away from the exhaust system.
Joe
Old Sep 1, 2005 | 09:07 AM
Blue SOG's Avatar
Blue SOG
benningtonr
2014-2024 Touring Models
11
Mar 4, 2017 07:10 PM
jvvjvv
Dec 15, 2013 06:46 AM
sharkey
Aug 22, 2010 07:27 AM
Sandcrab
Electrical/Lighting/Alarm
Mar 2, 2010 10:36 AM
floydpink
Sep 7, 2007 10:54 AM
