Gerbing adaptor to battery tender wire
Old Dec 14, 2013 | 08:03 PM
jvvjvv's Avatar
jvvjvv
Default Gerbing adaptor to battery tender wire
On my Road King, I have the panel mounted plug-ins for my Gerbing gear. I want to use the battery tender......( do not know the name of the quick disconnect plug)........ plug, already on my Buell. I went on Gerbing site and there is no adapter for the RCA type to the battery tender type.
I'm sure I can go to an auto parts store and buy the plug and just splice the wires to the Gerbing stuff, But would prefer to have a factory made piece.
Any ideas? Thanks..........
Also..what are the battery tender dual ends called???
Old Dec 14, 2013 | 08:06 PM
pat1's Avatar
pat1
I've done it and it worked perfect. I went to the motorcycle store and bought another battery tender lead for 7 bucks.
Old Dec 14, 2013 | 08:08 PM
davidwruth's Avatar
davidwruth
If you heat shrink the connection splicing it should be fine
Old Dec 14, 2013 | 08:09 PM
Veekness's Avatar
Veekness
Some folks call 'em pigtails...
Old Dec 14, 2013 | 08:21 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the pigtail wire is not large enough for the heated gear,it can easily melt and short.
Old Dec 14, 2013 | 08:45 PM
0ldhippie's Avatar
0ldhippie
First Gear make a pigtail.
http://www.motorcycle-superstore.com...x-plug-adapter
Old Dec 14, 2013 | 09:03 PM
jvvjvv's Avatar
jvvjvv
Oldhippie....... That's it!! Thanks all for your answers.
Happy holidays!
Old Dec 14, 2013 | 11:51 PM
kokemill's Avatar
kokemill
Default This is wrong - the pigtail works fine
This is wrong, here is a link to a post where I compared the tender pigtail to the Gerbing pig tail. Reply #21
https://www.hdforums.com/forum/touri...l#post11941369
The pigtail adapter is available from HD. I used it last week for 18 hours straight with gloves and jacket both set to max as I outran a snowstorm. No problem.
Old Dec 15, 2013 | 06:38 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
When I first got my heated gear, it was ill advised to use the battery tender plug. Something to due with amps. And not having a in line fuse.
Fast forward today (2 weeks ago) local HD dealer had them for like $7.95 or $8.95 on their heated gear rack.
One of my riding bros got one at a BMW dealer for $10.95 but after researching it, he also elected to return it and use the the one with the inline fuse.
YB
Old Dec 15, 2013 | 06:46 AM
EasternSP's Avatar
EasternSP
One of the primary things you should look for in a connector other than the ability to carry the current is it's quick disconnect feature. When ya get off the bike after riding, ya will, on occasion forget to disconnect it. If it's a tight connection, you may rip the wires apart or from the battery posts. The Gerbing connector was made with this kind of incident in mind.
benningtonr
2014-2024 Touring Models
11
Mar 4, 2017 07:10 PM
rowle
Jun 28, 2014 11:21 PM
Sandcrab
Electrical/Lighting/Alarm
Mar 2, 2010 10:36 AM
sportster2
Nov 10, 2008 06:43 PM
floydpink
Sep 7, 2007 10:54 AM
