FOUND THE PROBLEM ----- QUICK -- HELP PLEASE
Old Mar 28, 2007 | 10:51 PM
DJVOLUME's Avatar
DJVOLUME
Default FOUND THE PROBLEM ----- QUICK -- HELP PLEASE
2007 FLHX....... went to crank ..... My battery isshot !!!!
Started pulling everything off to get to it... Disconnected rear speakers... removed the Tour-Pak... THEN IT HIT ME.
I have NO IDEA how to remove my driver's backrest -----
What an idiot I feel like asking this question.
I am assuming there is some sort of qucik release that must be pushed or pulled??
Please help.... THANKS
Old Mar 28, 2007 | 11:13 PM
06TEXASCLASSIC's Avatar
06TEXASCLASSIC
Default RE: QUICK -- HELP PLEASE
Dont know about your drivers back rest, but you dont have to take the tour pack off. You can use a long screw driver between the passenger back rest and the back of the seat.
Old Mar 28, 2007 | 11:14 PM
Ram's Avatar
Ram
Reach your hand down in the hole of the seat. The back rest will have metal rods on right and left side.
Squeeze them together and rock drivers back rest to the left and right it will then pop straight up.
Old Mar 28, 2007 | 11:24 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Wow, you removed the TP?[sm=icon_rtfm.gif]
Old Mar 28, 2007 | 11:28 PM
DJVOLUME's Avatar
DJVOLUME
Yes it's the FLHX... with Speakers and a quick detach Tour Pak -------- removing the Tour pak takes 2 secs.
Old Mar 28, 2007 | 11:33 PM
EasternSP's Avatar
EasternSP
Your battery is shot on an 07? Geez, what do you do with it? Power your house?
Old Mar 28, 2007 | 11:35 PM
Hammer02's Avatar
Hammer02
Did you check the kill switch?
Just asking.
Old Mar 28, 2007 | 11:37 PM
DJVOLUME's Avatar
DJVOLUME
THANKS RAM
Takes all of..... nothing... .... just squeeze together and pull.
Thanks Bro
Old Mar 28, 2007 | 11:44 PM
DJVOLUME's Avatar
DJVOLUME
There is a kill switch????
LOL
It has a little juice... lights will come on dim....But not enough to run the fuel pump... it tries.
I am assuming.... when they installed my rear speakers... they left it ontoo long.
OR
worst case scenario there is a problem with the charging system.
I talked to my tech guy... he is going to run a diag. on it.. once I get it charged up and get it to the shop. He said no prob. --- anything will be covered under warranty.
The fact that it was 80 degrees yesterday and I wanted to ride is NOT covered under warranty though.
Ram's Avatar
Ram
ORIGINAL: DJVOLUME
THANKS RAM
Thanks Bro
No problem, your quite welcome
