DOT vs. Novelty
Old Sep 15, 2005 | 04:18 PM
  #31
softtail3005's Avatar
softtail3005
Former Sponsor
Default RE: DOT vs. Novelty
I have looked at both NXT and ACC DOT helmets on line. Any views on the advantage of one over the other??
Thanks
Old Sep 15, 2005 | 04:22 PM
  #32
Screamer's Avatar
Screamer
I have seen both in person. ACC smaller and lighter.
Old Sep 15, 2005 | 05:27 PM
  #33
Cohiba_Joe's Avatar
Cohiba_Joe
Hey kechour....
Have you, by chance, had the opportunity to compare the ACC DOT helmet to their non-DOT helmet in person?
Just curious.
Brian
Old Sep 15, 2005 | 05:31 PM
  #34
Screamer's Avatar
Screamer
No sorry. Only seen their non-DOT on the web.
Old Nov 11, 2005 | 08:07 PM
  #35
NJSUPERGLIDE's Avatar
NJSUPERGLIDE
HI,
Was wondering if anyone actually owns and has worn the above mentioned ACC dot helmet and what their opinion is on it. As I am considering purchasing one . RIde Safe!
Thanks,
Frank
Old Nov 11, 2005 | 10:25 PM
  #36
Cohiba_Joe's Avatar
Cohiba_Joe
Hey SuperGlide.....
I can give a big thumbs up on both the ACC helmets. I bought one of each. The wife wears the DOT and I wear the non-DOT. I bought the two with the intention of returning one of them and doing an exchange. But as it turns out we each liked the different one. The DOT is a tad bit larger than the non but not by much. It just turned out the no-DOT fit me better and was more comfortable...same with my wife on the DOT fitting for her.
I would not hesitate to buy another one if need be.
Hope this helps,
Brian
Old Nov 11, 2005 | 11:11 PM
  #37
myzen's Avatar
myzen
I have no experience with the ACC brand but I love the NXT carbon fiber with visor. In my opinion it is one of the lightest and best fitting helmets I have owned. I used to wear one of the HD helmets and I would experience a lot of wind noise and turbulence with it. The NXT is narrower and cuts nicely through the wind nicely. Be sure to try one on for proper fit. They run a little small. I ended up with a Medium+ and I usually wear a Med in others.
Old Nov 11, 2005 | 11:54 PM
  #38
Roadking1679's Avatar
Roadking1679
I have accumulated probably 6 or 7 helmets over time. The ACC non DOT is the helmet of choice. Excellent fit and secure enough for me. It was cold last week and I put the full coverage HD on only to remove it in favor of the ACC and Schampa mask. Once you wear a good ACC, it's hard to wear anything else.
Jeff
Old Nov 12, 2005 | 12:23 AM
  #39
traveler's Avatar
traveler
ORIGINAL: pilot1996
I was looking at novelty helmets for when I ride into CA...I came to the conclusion that if I'm going to wear one, it might as well be capable of doing it's job. I would recommend shopping until you find a DOT that you like. Seems like if you are going to bother with it, you might as well get something out of it.
Mac
Friendly reminder:
If you are in the military, then REGARDLESS OF RANK, you are REQUIRED to wear a DOT helmet at ALL times, along with gloves, boots, long sleeve shirt, pants, etc. IT'S NOT AN OPTION!!!!!!
joe
Old Nov 12, 2005 | 01:52 AM
  #40
metalgirl247's Avatar
metalgirl247
I have that helmet in the glossy black...... I really like that zip off thingy...cuts down on the wind noise and feels cozy...when I wear it[sm=guilty.gif]
It does kinda make me look like an alien cause the shell seems so big!
I wear an XS..
MG
[IMG]local://upfiles/5328/E63CD95A5BA74DDE83D894C08DE2C802.jpg[/IMG]
