Got a voltage problem
Old Sep 9, 2014 | 09:34 PM
Puggy's Avatar
Puggy
Default Got a voltage problem
Kind of a long read but here goes.......
Riding an 08 Street Glide. Installed a new battery about 2 months ago from Batteries +. A few days ago, I noticed that just pulling in the clutch that I was getting static noise coming from the radio. Thought maybe the clutch cable was pulling on the antenna connector on the back. Pulled the fairing and checked everything, nothing found. Made sure all connections were good and buttoned it up. Been keeping any eye on my voltage regulator since then and it's been showing just a hair over 14V. Tonight, get on the bike to ride home from work. Pulled out on the highway and when I hit 3rd gear the engine and battery dash light came on. Pulled over and shut it off. Turned back on and no lights. Got back out and again battery and engine light came on. Noticed that the voltage meter was showing 11.5V. It never dropped below that all the way home. Checked battery voltage and it showed 12.1 volts, lower than it should be but ok. Started bike and voltage went up to 12.4 and increased when engine revved, again, as it should. Went ahead and checked wire continuity from stator and it checked good.
I'm thinking the new battery has a bad cell. What do the experts think?
Old Sep 9, 2014 | 10:47 PM
hoethree's Avatar
hoethree
Funny
Have simki
Have similar issue with GF's Softail Deluxe. Watching.
Old Sep 10, 2014 | 07:09 AM
nhrider1's Avatar
nhrider1
I think you have a problem with the voltage regulator.
If you had 11.5V with the bike running, the voltage regulator is bad. It may be intermittent, but its bad.
MURPHCC1
Electrical/Lighting/Alarm
Sep 11, 2017 07:31 AM
newstreetglide
Oct 11, 2015 09:01 PM
mack03
Jul 17, 2015 06:51 AM
TooEasy
Dec 19, 2012 05:19 PM
06yellowrg
Aug 4, 2007 03:57 PM
