Speedo Cable Replacement
Old Sep 11, 2005 | 06:08 PM
troglodyte's Avatar
troglodyte
Default Speedo Cable Replacement
1980 Super Glide
Speedo isn't working. Pulled off the gauge and unscrewed the cable. Pushed the bike and the drive didn't turn. Therefore I suspect a broken cable. No big deal except, how do you get the cable out of the unit on the front wheel?
Mike
Old Sep 11, 2005 | 06:58 PM
ecvjohn's Avatar
ecvjohn
Default RE: Speedo Cable Replacement
Different bike but I just did this on mine, the cable unscrews at the wheel unit, mine has two flat spots to grab on with a wrench, hard to see them though, it took about 5 minutes total. Make sure your cable is fairly straight and diconnected from the speedo when unscrewing it.
Hope this points you in the right direction and that yours is somewhat the same.
Old Sep 12, 2005 | 12:44 AM
troglodyte's Avatar
troglodyte
Thanks.
I didn't see any flat spots but if they are hard to see I'm sure I missed them. I'll check again.
Love that color scheme John, very classic.
Mike
Old Sep 12, 2005 | 04:16 AM
ecvjohn's Avatar
ecvjohn
On mine it was the very end of the cable near where the black meets the metal, if that makes sense. I used a pair of pliers and was gentle until I figured it out. On mine it didn't look like it would screw out, but it did.
Old Sep 13, 2005 | 12:59 AM
troglodyte's Avatar
troglodyte
Figured out how to get the cable out. After I pulled the whole collar out I figured out the cable just twist screwed out. Oh well, the collar fit back in without an problems.
Cable is good. Twist one end, other spins. Looks like it is the front wheel unit. Another $35.
Guess I'd better get a JPs catalog. Then I can compare thier prices with DK.
Mike
Old Sep 13, 2005 | 01:14 AM
ecvjohn's Avatar
ecvjohn
Did you check the speedo where the cable goes in? It may be stripped out. I checked mine by inserting the lower end of the cable into a drill in reverse mode. Mine read 20mph.
Hope you get it going soon.
Old Sep 13, 2005 | 04:03 PM
troglodyte's Avatar
troglodyte
Did same - cable and speedo work.
Thanks for the suggestion. I would have really been hacked if I ordered a new drive unit and it was the speedo.
Mike
72shovel92softail
Jul 27, 2015 05:11 PM
StlJimmy
Apr 2, 2015 10:50 PM
johnod
EVO
11
Sep 15, 2014 08:52 PM
redhead356
Ironhead
Nov 7, 2012 04:31 PM
