Clearing codes on a 2003 Deuce
Old Nov 28, 2014 | 04:26 PM
Cowboy Rapiardi's Avatar
Cowboy Rapiardi
Stage IV
Default Clearing codes on a 2003 Deuce
Is there a way to clear historic engine codes without a scanteck? The way the book calls for it to be done is to cycle the engine 50 times. Each cycle is to start the bike and let run for 5 seconds and shut off? I have done this and the same 2 codes stay in the memory. The Map sensor has been replaced and there are no currant codes, yet cycling 50 times didn't work. I have a slight problem running the starter so much. is there a time I need to wait after shutting down or an immediate start up?Anyone have a suggestion?
Old Nov 28, 2014 | 07:06 PM
PTSDBob's Avatar
PTSDBob
… the 'old' way was to disconnect the battery (+pos) cable…
Old Nov 28, 2014 | 08:40 PM
Deucedog's Avatar
Deucedog
Courtesy of fuel moto's website:
http://www.fuelmotousa.com/harleycodes.html
Courtesy of HD Forums:
https://www.hdforums.com/forum/softa...des-dtc-s.html
I'm sure you'll find some help in those.
Old Nov 28, 2014 | 11:06 PM
HDmikie's Avatar
HDmikie
There ya go....listen to Bob.
DayzedAndKunfoozed
May 2, 2018 04:28 PM
planethax
May 2, 2015 06:45 PM
Cowboy Rapiardi
Nov 29, 2014 12:57 PM
kschmid
May 6, 2012 12:24 PM
planethax
Sep 6, 2010 04:00 PM
