Need some help guys
Old Feb 25, 2015 | 09:22 PM
dirtyderz's Avatar
dirtyderz
Default Need some help guys
so i have an 04 sportster 1200r and i want to put on some engine trim pieces i picked up and that requires me to remove and put back in the bolt that is above the vin on the left side of my motor. It is the bolt thats above the primary and right below the motor. My questions are what is the name of this bolt and what is the torque spec to put it back in? Will anything happen once i take it out or will i have to replace the bolt itself when i take it out? Thanks alot for any help
Old Feb 26, 2015 | 11:22 PM
dfwhockey17's Avatar
dfwhockey17
A picture would be helpful. Do you have a manual? If not, get one as it will help you out a ton and pay for itself after the first few uses!
Old Feb 26, 2015 | 11:26 PM
harleyultra1969's Avatar
harleyultra1969
Usually if a trim piece requires a longer bolt, it will come with a longer bolt. But yes, I agree with hockey, before you go tinkering with your bike get yourself a service manual.
Mikeduke108
Jun 20, 2014 02:46 AM
CSS_FXD
EVO
Feb 18, 2012 09:55 PM
RidemyEVO
EVO
Feb 16, 2011 05:11 PM
joel85
Apr 29, 2008 07:39 PM
