Brake line compatibility
Old Jun 2, 2015 | 05:14 PM
Don Lampert's Avatar
Don Lampert
Default Brake line compatibility
So I guess no one really visits the brakes thread....
Got a question for anyone who can help.
I have a 97 Dyna with the front dual disc brakes.
I need the brake line from the master down, found one for an 01 road glide, part number 43350-08 no abs.
Can't find any compatibility information for this part number for any bikes but im assuming that a brake line is a brake line and I wouldnt assume that any of the fittings or anything like that were changed bike to bike.
Wondering if any one in here has any idea if this line will work with the 97 fxd.
Old Jun 2, 2015 | 08:00 PM
lt1-xjs's Avatar
lt1-xjs
The 43350-08 line is for the '08 up touring with Brembo brakes. I believe you need part no. 45111-96. If the line is free give it a try, it may fit.
Old Jun 3, 2015 | 09:05 AM
grbrown's Avatar
grbrown
The bikes are different shapes in various ways. The touring bikes have wider trees and handlebars, also an upright riding position, so the '08 lines will not be identical to your Dynas, however the only differences will be in the lengths of the various parts.
Personally I wouldn't use any secondhand brake pipes, if that is what you're looking at. If your bike is an '07 it probably uses DOT5 brake fluid, while I suspect an '08 uses DOT4. Personally I would make a fresh start with a braided pipe set, readily available on Ebay for around $80, take a look at #231535707674.
Don Lampert
Jun 2, 2015 11:35 AM
2013superglideseattle
Aug 6, 2014 09:38 AM
Vinsil
May 23, 2012 03:12 PM
Apr 13, 2010 08:43 AM
DVassino
Sep 5, 2009 09:31 AM
