06 street glide electrical problems.
Old Jul 22, 2015 | 05:52 PM
UFO8MyCow's Avatar
UFO8MyCow
Default 06 street glide electrical problems.
I have a 2006 street Glide that has been acting up all year. I had the bike torn down to motor and frame over the winter and ever since I have been getting random check engine and security key lights while I'm riding and it has been throwing several codes that indicates both speedometer and TSM
The codes are
65. P1356 Rear Cylinder No Combustion
5. U1097 Loss of Speedometer Serial Data to ECM
4. U1255 Serial Data Error
3. U1016 Loss of ECM Serial Data
6. U1064 Loss of TSM/FSFM Serial Data to ECM
It has never not started or ran bad but sometimes the speedometer and tachometer will just quit working all together. Last week I drove over 20 miles without any indication from the speedometer odometer or tachometer
Old Jul 24, 2015 | 02:04 PM
tdgriff's Avatar
tdgriff
Are all your wires in your dash hooked up right? If you wiggle your ignition around does it help?I would take the dash off with all wires still hooked up and see what happens. Sounds like pintched wires.
Old Oct 24, 2017 | 04:24 PM
Fusilier7316's Avatar
Fusilier7316
Stage I
Hi Im having very similar problems, a wire broke on the air intake sensor connection this has a sensor replacement ( forgot what they are called ) as it has a power commander on this brings up engine management light But now I have battery light and red key light coming on intermittently , tonight after pulling up it decided not to run, it will start but then not tick over and cuts out.
Please Help cheers
scaraboy2
Jul 9, 2018 02:50 AM
barrybrockway
Electrical/Lighting/Alarm
Apr 10, 2018 10:22 PM
emerican19
Mar 4, 2012 05:19 AM
kyBriar
Feb 3, 2010 09:19 PM
dogtags
General Topics/Tech Tips
Oct 25, 2007 04:14 AM
