bolts???
Old Aug 20, 2015 | 05:57 PM
outcast69's Avatar
outcast69
6th Gear
Default bolts???
i know this sounds NUTS ,,,but what is the proper name for the bolt that hold on the front brake calipers on touring models. thanks .
Old Aug 20, 2015 | 06:37 PM
Uncle Larry's Avatar
Uncle Larry
Actually it sounds "bolts" ... and you'll need to supply a bit more information for the correct part. Caliper Mounting Bolt ( the bolt that attaches the caliper to the lower leg ) on a ???? 2009 Dresser is a 44160-00 ... I have no idea what you're riding :>)
Old Aug 20, 2015 | 06:44 PM
davidwruth's Avatar
davidwruth
+ 1 On caliper bolts.
Old Aug 20, 2015 | 07:04 PM
outcast69's Avatar
outcast69
6th Gear
I ride a 2012 Electra glide ultra, and yes, the caliper mounting bolts , what's the name of that type of bolt ? Has all the groves in it , thanks
Old Aug 20, 2015 | 08:26 PM
davidwruth's Avatar
davidwruth
It's a caliper bolt. Not sure what you are trying to find out. If it's the size wrench or socket. Use a 12 point 10 mm. Do u need to replace them. They come with the pads from HD as well as the clip if that's what you mean?
Old Aug 20, 2015 | 08:34 PM
outcast69's Avatar
outcast69
6th Gear
thanks David ,,ya thats what i wanted to know ,,i was just reading a few posts about that, seems lots of guys use metric , not that it matters ,guess im just old lol , thanks again.
Old Aug 20, 2015 | 10:52 PM
dfwhockey17's Avatar
dfwhockey17
^They use metric because they are metric...
Old Aug 21, 2015 | 07:28 AM
outcast69's Avatar
outcast69
6th Gear
Oh , I've never taking them off before , I just assumed all bolts on Harley's were standard , just waiting for new front tire to show up , then I'm going to take them off , guess I should never assume , lol
Old Aug 22, 2015 | 08:07 AM
dfwhockey17
^Wheels/suspension/brakes are Showa/Brembo....metric stuff!
Kennypatterson
Feb 28, 2014 11:43 AM
DISTURBEDCUSTOM
May 18, 2012 06:49 PM
pip369
Wheels/Tires
11
Mar 16, 2009 06:52 AM
nobarking
Wheels/Tires
Feb 23, 2009 08:22 AM
stevec314
Apr 18, 2008 10:22 AM
