Unsolvable problem
Mods: I believe all he has done is pipes and a tune. Noise started long after mods.
Miles: Approx 3500
What HD has done.
Replace rear rotor and pad
Inspected possible "air gap" between wheel and rotor, and filled with silicon
Inspected transmission and rear wheel bearing
Said everything was good each time...only for him to get the noise after riding for 20+ minutes.
Any ideas? They just picked the bike up for the fifth time, and he has been in contact with the regional guy...but figured I would post here to see if any of you have any ideas.
Hope all the links work.
Thank you in advance.
Brake cylinder not bleeding off pressure after using the brake and or pads not retracting away from the rotor?
Do not use the rear brake and drive around to see if rotor or pads are getting hot indicating a dragging pad.
Use a infrared temp gun to see what the bearing hub or rotor temp is? Or just feel them after a ride.
Remove rear brake pads and go for another ride and see if it eliminates the problem? If you do this, do not use the rear brake! Use front brake only and only do this in a remote area for diagnostic purposes only!
Make the dealer take it for a 1/2 hour ride or however long it takes till the sound usually comes back before you take the bike back home. YD
Just some guesses as to what may be the problem. YD
Thanks Yankee Dog.
They said the wheel bearing was good. I didn't think about checking the surface temp on the rear rotor. HD picked the bike up again today, and offered a loaner ride. When he tells me what the issue is...assuming HD finds out, I'll let you know.
Contact the MoCo and tell them the issues with the repairs not fixing the bike.
Find a different dealer for the repairs.
