Spit, sputter & backfire @ 80mph
Old Sep 28, 2015 | 04:26 PM
awilcodm's Avatar
awilcodm
6th Gear
Default Spit, sputter & backfire @ 80mph
I have a 2003 RK. On the way home from work the other night it started to spit, sputter and backfire through the pipes. Initially I though I was running out of gas but I had 1/2 tank. Luckily I made it home. I shut it off expecting it not to start but it fired right up. I let it sit until the weekend and when I went to start it there was nothing. The battery was "new" in the spring by the previous owner but when I took it to have it checked they said it was bad. Now for the back story...2 days prior to the bike running bad, I left my ignition on while at work and killed the battery. I had to have it jumped in order to get home. Could that have did my battery in? I have since bought a new batter and have put about 75 miles on with out issue. Do you think my problem is fixed or is there an underlying culprit waiting to rear its ugly head? Any help is appreciated.
Also, would anyone care to explain how the charging system works on these bikes?
Old Sep 28, 2015 | 04:37 PM
TriGeezer's Avatar
TriGeezer
Could be...batteries don't like to be run dead. Once that happens, its best to replace it.
Old Sep 30, 2015 | 07:57 PM
awilcodm's Avatar
awilcodm
6th Gear
Thanks for the reply. So far so good on the new battery.
Old Oct 1, 2015 | 10:06 AM
dfwhockey17's Avatar
dfwhockey17
Have you checked the charging system to make sure the stator and regulator are working within spec?
Old Oct 1, 2015 | 06:38 PM
awilcodm's Avatar
awilcodm
6th Gear
I have not. How can I check that?
Old Oct 1, 2015 | 08:50 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Once you "kill" the battery by running it completely down it will never be the same and will only create more issues. You can go to www.youtube.com and watch a couple of videos that shows how to properly check the charging system.
Old Oct 2, 2015 | 12:29 AM
Next In Line's Avatar
Next In Line
Do a fuel pressure test also. The fuel pump hose in the tank gets a small hole in it and would also give the symptom of running out of gas.
Old Oct 2, 2015 | 04:04 PM
awilcodm's Avatar
awilcodm
6th Gear
Thanks for the info!!!!!!!
Old Oct 4, 2015 | 09:07 AM
HDmikie's Avatar
HDmikie
Yep, this happened to my 02 Fatboy last year. Change the filter while you're in there. The OP didn't say if his bike was carb or EFI.
JRankin163
Electrical/Lighting/Alarm
11
Dec 3, 2019 05:30 PM
Soft2012
19
Jun 24, 2018 04:12 PM
windy blue
Sep 22, 2017 04:16 PM
voudoujoe
15
Aug 24, 2016 03:07 PM
chromefatty
Jun 19, 2011 10:19 AM
