Painting Engine
Old Nov 4, 2015 | 03:19 PM
Rogue8Man's Avatar
Rogue8Man
Default Painting Engine
So the some of the paint is peeling off my 99 RoadKing heads and barrels. Thinking bout taping the fin edges and then painting with high temp paint and foam brush (to get between fins). Any suggestions, tips or comments would be appreciated. TIA.
Old Nov 4, 2015 | 07:02 PM
Lowrydr2's Avatar
Lowrydr2
2nd Gear
Default lowrydr2
Got a good tip for painting motor. First clean off any dirt, Get some flat black engine paint and spray the paint directly onto Q tips. They fit well between the fins. It may take a few coats to look good but it works good without much mess or masking. If you get a little on the fins just use a small piece of fine sandpaper to clean paint off. I've done this several times and it always holds up!
Old Nov 5, 2015 | 08:13 AM
Rogue8Man's Avatar
Rogue8Man
Thanks lowrydr2. I will use this when I do the project.
dakotav8
EVO
16
Dec 26, 2016 05:52 PM
STN
Powdercoat & Paint
Jan 17, 2016 07:42 PM
tonetls
May 19, 2014 03:53 AM
ihb75
Jun 19, 2012 03:12 PM
nyxhc93
Nov 6, 2011 12:14 PM
