Fuel Gauge malfunction
Old Dec 17, 2015 | 09:57 AM
hoosierbagman's Avatar
hoosierbagman
Default Fuel Gauge malfunction
I have an '06 SG and I'm having a prob w/ the fuel gauge. When I first start up, it works ok, but after a mile or two, the needle drops over to E. At first, it would intermittently start working again, but now it stays on E unless I let it sit for quite a while, like overnight. Then the same thing happens all over again.
I suspect the fuel sender is going out, but I suppose it might be the gauge itself. Could be an ex-wife's curse or karma, but I'm thinkin' it's mechanical.
Any thoughts or suggestions?
Thanks.
Old Dec 17, 2015 | 10:37 AM
grbrown's Avatar
grbrown
It would be worth removing the sender from your tank to inspect it. You should be able to check it electrically, while in your hand. Take precautions not to cause a spark! If it's the same style as mine, you have a float, which wipes a contact over a fine coil. You may be able to persuade the two to make better contact (i.e. bend something!). You should at least be able to confirm if the sender is the problem.
Old Dec 20, 2015 | 08:51 PM
hoosierbagman
Thanks, grbrown,, I'll give it a try.
Barz
Aug 24, 2021 01:23 PM
Stan_O
Electrical/Lighting/Alarm
May 26, 2014 01:25 PM
Bigdaddysstreetglide
General Topics/Tech Tips
Aug 23, 2011 07:45 PM
gedo76
Mar 3, 2009 04:16 PM
Heritage Dream
Feb 20, 2007 06:15 PM
