EBC Brake question
Old Mar 14, 2016 | 08:11 AM
twitchcvma's Avatar
twitchcvma
Default EBC Brake question
changed OEM brakes ( I think they are Brembo) at 8K miles with EBC brakes. I noticed the first 50 miles or so they would not grab well. They kinda slid through the rotors. After 50 miles or so they grab great. Thought it odd. Changed them again at 15,140 miles with EBC. same feeling. Just not grabby for a few miles. Has anyone else experienced this? Is this normal for EBC? Are Brembo brakes that much better?
Thank you
T
Old Mar 14, 2016 | 10:25 AM
grbrown's Avatar
grbrown
These things can be different between different brands. It is routine that a change to aftermarket will give improved braking performance, partly because some brands use softer materials, which wear more quickly. What you have experienced is not unusual. I am about to fit a full set of EBC rotors with pads, although it will be a while before I'm back on the road to compare notes. I won't be worried if mine do the same as yours.
Old Mar 14, 2016 | 11:56 AM
nevil's Avatar
nevil
I replaced my front pads with EBC. Just like you said, it took a few miles for them to break in so I just compensated for it. Once they were bedded in, they worked way better than the stock pads. Very happy with my choice.
Old Mar 14, 2016 | 12:02 PM
Notgrownup's Avatar
Notgrownup
They need to bead in good... I like to scuff mine up with a 30 grit sand paper (couple passes) and then brush them with a stiff brush to get anything off...
All I have used is EBC double sintered since the first pad change on my 07...They are the best IMHO.
Old Mar 21, 2016 | 08:08 PM
Sierra977's Avatar
Sierra977
You do know you have to break-in new brake pads, yes? Do the stop-start cycles as recommended by manufacturer or google "brake break-in". You will screw up brake pads for life if you don't break them in properly. I use EBC "Red Stuff" or "Blue Stuff" ceramic pads on my car and they are very good pads.
Old Mar 22, 2016 | 12:52 PM
jamess71's Avatar
jamess71
What he said.
jammerx
2014-2024 Touring Models
May 26, 2017 04:18 PM
Bigdaddy1122
Sep 27, 2012 02:21 PM
sioux565
Sep 10, 2012 08:33 AM
BEN-Z
Apr 9, 2009 12:06 AM
Neckball
May 23, 2007 10:32 AM
