Code P0118 ET sensor open or high
Old May 31, 2016 | 05:43 PM
Rtl4042's Avatar
Rtl4042
1st Gear
Default Code P0118 ET sensor open or high
I took my 08 Heritage Softail to the car wash Saturday, after washing it up I cranked her up and the check engine light came on. I figured out how to check my codes and P0118 came up in which its ET Sensor open or high. Why would this happen after washing it? I've looked for loose wires but cannot find any. I'm not sure where the sensor is, my manual says its one place and online it says it somewhere else. Looked in both places and still saw no loose wires. Could it be a fuse?? Please help
Old Jun 1, 2016 | 03:44 PM
SBates08's Avatar
SBates08
The Engine Temp Sensor is right behind the horn screwed in to the back of the front cylinder. Had issues with mine as well. Mine turned out to be a broken wire in the harness. Wire was broken inside the wire sheath.
Old Jun 1, 2016 | 04:00 PM
Rtl4042's Avatar
Rtl4042
1st Gear
Default Is the plug in totally inclosed
Attachment 474095
I see something there but it is totally covered with some sort of a boot. Does that sound familiar? And the picture was way blurry to the point I couldn't see it. Thanks for the reply!
KennyPowerz
General Topics/Tech Tips
Jun 6, 2018 10:30 AM
nighty0619
Apr 26, 2015 06:48 PM
JEdwardsJr
Sep 27, 2014 06:52 PM
02 heritage
Electrical/Lighting/Alarm
Sep 10, 2014 09:31 PM
Mast1017
May 1, 2013 07:31 PM
