Need --- Motorcycle Winter Hibernation Tips!!!
Old Nov 6, 2016 | 08:03 AM
streetjoebob's Avatar
streetjoebob
Default Need --- Motorcycle Winter Hibernation Tips!!!
hello fellow riderz,
i just spent 4 years in hawaii riding my precious street bob, and now i am in the "north country" of new york (30 mins from canada). i am preparing for my first winter hibernation of my bike, and just wanted to know any tips someone might have from experience. the temperature will be in the negatives (-40F at the lowest) between Jan - March. My bike will be in a detached garage with NO heat source...
research form online only has these suggestions:
-wash bike
-change oils
-fill up gas tank with fuel stabilizer
appreciate any input!!
ride on!
Old Nov 6, 2016 | 08:26 AM
sharpcanoe's Avatar
sharpcanoe
If you cannot put the battery on a charger then I would take the battery out and put it someplace warm for the winter. ... Also take your handle bars off and hook them in front of a fan in your apartment/house so you can turn the fan on and pretend your riding in the wind during the long winter months... cabin fever usually hits around the end of January...
Old Nov 6, 2016 | 08:43 AM
Iceman24's Avatar
Iceman24
Some additions:
- Breathable cover, or cotton sheets, to keep dust off.
- Place ball of tinfoil in end of exhaust/muffler (keep critters out).
- Buy/connect battery tender.
Also, some might think it's unnecessary, but I also fog/oil the cylinders. Had a snowmobile engine seize in MN once...$pendy le$$on...your call.
Cheers!
Old Nov 7, 2016 | 05:59 AM
grbrown's Avatar
grbrown
Check your owners manual, that has quite enough info. I live further North than you, although in the UK and in almost 50 years have never spent any significant effort before storing any of my bikes. We didn't know we were supposed to back then!
Old Nov 7, 2016 | 07:59 AM
duglaura&flhti's Avatar
duglaura&flhti
-wash bike
-change oils
ride on!
Concur with HDF members above, plus get the tires off the ground with a lift, if possible, the have tires on thick carpet to avoid low spots on tires....Fuel stabilizer or sea foam for tank....Keep on tender all winter or store in warm controlled room. Good luck and thanks for your service. Go 10th Mtn.
J.R. White
Sep 2, 2012 12:18 PM
studiopeg
Dec 19, 2011 11:04 AM
dblkick
Aug 4, 2010 04:26 PM
moondog99
Dec 6, 2009 10:38 AM
NumberingRavens
Sep 26, 2007 10:02 AM
