Po563 -HELP
I may have figured out the problem . I rechecked voltage on battery and as I increased rpm' s voltage rose to17.5 . Voltage regulator? Do you think this a correct diagnosis
Originally Posted by RIPSAW
Yes but from afar and I hate to call errors. That is the first call out for high voltage. The low call out is loose wire. When you get a high it says check charging system. Pretty easy check since you have to disconnect the 3 wires coming from stator to regulator. Make sure thoes 3 wires are not going to frame ground with you ohm meter. The check all three combinations for ohm resistance. If that is OK, the finial check would be running with them checked all three combinations for equal AC out put.
If the stator is OK, I am with you on the regulator. Make sure that battery is OK and has no shorts. Something took that regulator out but it could have worn out also.
Originally Posted by Oldgreazer
thanks, I will check this evening.
All base reading are at 2000rpm. Voltage should be apx 32-46 volts AC (16-23 per 1000 rpm) Your test sounds normal.
0.1-0.2 ohm resistance across leads.
Sounds like regulator to me. From your charged battery reading, sounds like battery is also bad. Could have a shorted cell. I sure would carry it in somewhere that has a good tester and check that battery before using it with a new regulator...
You better be above average garage mechanic for it.
Since it's leaking, make sure the vent on transmission is open with no mud dobbers. That's what vents primary.
Also on the 07 the rotor will not clear the primary casting.
$180 may not be bad, if it comes with warranty and peace of mind.
Do not understand the cca being too high and a fully charged battery only reading 12.4 volts. That is only about 65% charged and means a shorted cell to me. However, a good tester would have shown that. If you can find a good tester. My local AutoZone's is garbage and after testing one for me, the O'Riley man said his was garbage also and it was new.
