starting issues
Old Apr 3, 2017 | 08:16 AM
shopnut's Avatar
shopnut
6th Gear
Default starting issues
I started up my 86 FLST after the winter break and all was good. A couple days later tried to start it again and the starter spun but didn't engage. I pulled the solenoid off cleaned the contacts, they were a little burnt. But still didn't engage. What are some test I can do for the solenoid and the relay? All help welcomed. Time to get some wind in my face....
Old Apr 5, 2017 | 08:02 AM
Yankee Dog's Avatar
Yankee Dog
Check your standing battery voltage - what is the voltage of your battery at rest, no charger, after sitting all night, key off.
It was a good starting point checking and cleaning your starter contacts, so no time wasted there, maybe post in the evo classics page on this site, probably get more replies. YD
Old Apr 5, 2017 | 03:59 PM
Clammy's Avatar
Clammy
Are you sure the pinion gear isn't coming out? Does it sound like this?
If so, your starter clutch is broken, and will need to be replaced.
Cheers!
Old Apr 5, 2017 | 04:31 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If the starter spins, but does not crank the engine, suspect the starter drive gear.
Item 19 in the illustration:
http://partsfinder.onlinemicrofiche....0BELT%20DRIVEN
thirsty
EVO
14
May 16, 2019 11:03 AM
metalfarm
21
Jun 1, 2016 07:30 PM
Rescuediver1982
EVO
Jul 28, 2015 08:39 PM
jason8251
Electrical/Lighting/Alarm
Jul 27, 2011 03:23 PM
rotorhd
Feb 8, 2008 08:25 AM
