General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Hi,
My 2013 FXDC has started cutting out when I shut the throttle when approaching a roundabout or queue of cars etc. It doesn't always do it, and usually restarts just fine.
Could it be the IAC? Any other ideas?
Thanks Guys - and Gals.
Clive
Yes, it could. And probably is.
Could also be battery and ground connections.
More info would help, such as miles, mods, tuner, etc. It's hard to diagnose a problem over the internet with so little background.
No mods apart fron Vance & Hines pipes, so it pops back a lot now.
I removed the air cleaner and sprayed carb cleaner up into the IAC. It was fine on the ride to work this morning so fingers crossed.
I'll check all the connections as well that you suggest.
Thanks for your help.
Clive.
