Seeking maintenance advice
Old Jun 10, 2017 | 11:55 PM
Douwe's Avatar
Douwe
Stage I
Default Seeking maintenance advice
Hey there folks, I'm just reaching out to get some general advice on maintenance. A buddy of mine has a Sportster 1200 that he hasn't started for literally over a year. He moved to a different town a few hours away but hasn't taken the bike back with him yet. We got it running, but obviously the gas is bad after all that time, so it wasn't running as smoothly as it could. My buddy isn't exactly a pro when it comes to maintenance and the bike has been pretty neglected in general, so we worked out a deal where I'll keep the bike at my place and keep it maintained until he's ready to take it back. In return, I get to use the bike whenever I feel like it, which will be super convenient in downtown Austin where parking is pretty difficult.
Anyways, I'm just looking for some advice on recommended oil types (brand & weight), decent air filters, common issues to look for, a good online company to order from that has good prices, and maybe where to find owners manual access online if possible. I don't necessarily want top of the line everything, but good price to quality ratio type stuff.
Basically just a run down of essential recommended maintenance.
I'm sure I need to give you guys a little more specific info to answer all my questions adequately, but I'm actually away from home right now, so I'll follow up later with that if/when needed.
My immediate maintenance plans include:
Oil change
Air filter change
Drain fuel tank
Clean carb or injectors (haven't even looked into it enough to see if it's carbed or FI)
Thoroughly clean the whole bike
Check for any loose bolts
Small adjustments and fixes to a couple items that got damaged in a minor crash.
Old Jun 11, 2017 | 04:49 AM
yooperbigdog's Avatar
yooperbigdog
Oil change
Air filter change
Drain fuel tank
what year and Miles, I'd do trans fluid (1qt) and primary fluid (1qt)-been sitting long time (check tires good), alway's scary using someone else's bike--if something breaks or there's a mech prob are you ready to spend a bunch on fixing someone else's bike ?? ain't nothing cheap on a H.D.
Old Jun 11, 2017 | 05:06 AM
Chriswalden88's Avatar
Chriswalden88
Online owners manual directly from HD along with lots of other useful documents including a full blown illustrated parts catalog can be found here:
https://serviceinfo.harley-davidson.com/sip/index
Just click on Independent operators and setup an account. It's completely free and super helpful. The owners manual will tell you all you need to know about maintenance schedule.
I agree with yooperbigdog, primary and tranny should diffidently get an oil change. I would add to that to check your primary chain tension and belt tension while your at it.
I also agree with yooperbigdog about riding someone else's bike, especially an HD. EXPENSIVE when something goes wrong. As for parts, quality parts can be found on J&P Cycles, DennisKirk.com and I buy alot of my gaskets right off of Amazon from a company called James Gaskets. Quality gaskets for a great price. Used those three resources for years.
Old Jun 13, 2017 | 09:56 AM
grbrown's Avatar
grbrown
Wink
You can see a parts breakdown for 'your' bike on-line here, which can be useful at times, also gives you the correct part number and description. You can get a factory service manual at your local dealer, but be aware that on-line downloads of them are illegal, as they break copywrite laws. The book will give you service schedules, oil quantities, torque data for fasteners and a whole lot more.
Old Jun 13, 2017 | 01:19 PM
yooperbigdog
grbrown thank's for the part's site, been looking for a site to find part #'s, THANK's
Old Jun 13, 2017 | 09:30 PM
OkieBill's Avatar
OkieBill
All as noted above. Critical fasteners, i.e. brake calipers, motor mount bolts, seat bolts, etc. Anything that will cause a catastrophic failure if left unchecked. Also brakes and fluid...fresh fluids are a given.
Be safe and see you on the roads.
Old Jun 14, 2017 | 10:05 AM
dfwhockey17's Avatar
dfwhockey17
The trans and primary share fluid on sportys so the OP will need 1 quart of sporty chaincase oil...
Old Jun 18, 2017 | 10:42 AM
chromepony's Avatar
chromepony
That right there from "dfwhockey17".
Old Jun 18, 2017 | 10:49 AM
Yamaharley's Avatar
Yamaharley
If it's been sitting a year or longer flush the brake fluid and put in new fork oil. Don't be surprised if you need to put a few hundred in. What's the date code on the tires? Unless you plan on buying the bike from him just bring it to him and let him pay to fix it.
Also what was a minor wreck? What is damaged? Your gonna have some $$ in this bike to get her running.
Old Jun 19, 2017 | 11:42 AM
1340hog's Avatar
1340hog
you do what you want with someone else's bike and if you can get a season out of her you will be ok.But,ya know whats going to happen?Just about the time you get it road worthy he's going to show up and say"gee i think i'll take my bike now"your looking at some money,time and labor to get it going with possibly very little satisfaction.i know this because the same thing happened to me 35 years ago.my father in law had a 1968 b.s.a. 441 with 3 inches of dust on it.he said he wasn't doing any thing with it.so me being young and stupid dragged it out ,spent money to get her going and low and behold!!!!he decided to sell it.i,m still pissed at that ***hole for doing that.I got some of my money back but thats beside the point.
bhoins
May 9, 2019 08:40 PM
QRUCK
14
Nov 27, 2018 08:23 AM
OldSalt
Southeast
Oct 7, 2012 07:14 AM
RazorFXDB
Jul 24, 2007 11:06 PM
Grover
Jan 1, 2006 11:00 PM
