Passenger Peg Slips
Old Aug 1, 2017 | 10:10 AM
ronaldrwl's Avatar
ronaldrwl
Default Passenger Peg Slips
One of the passenger pegs slips down while riding. It has a pin and clip holding it on. Has anyone tried adding a thin washer to stiffen it up? Or, something else?
Old Aug 1, 2017 | 11:51 AM
nevil's Avatar
nevil
I thought it would have a thin spring washer in there. If not, that's easy enough to do. Check the other side, too.
Old Aug 2, 2017 | 02:26 PM
dfwhockey17's Avatar
dfwhockey17
There should be a 'D' or spring washer between the peg and clevis to help hold it up. Sometimes those flatten out and fail, or the tolerance is just too loose with one washer. You can swap the pin/circlip for a bolt/nylock nut and tighten it down to hold it better, or you could try new, or possibly, two D washers...
cmosentine
Aug 4, 2013 10:34 AM
"HI"
May 13, 2013 08:38 PM
mike1158
Aug 7, 2012 01:45 PM
azfathog17
Mar 9, 2009 01:57 AM
ken thompson
May 1, 2007 04:08 PM
