Help please
Old Nov 11, 2017 | 09:42 PM
mjeddy78's Avatar
mjeddy78
6th Gear
Default Help please
I bought a badlands illuminator tail-turn-brake for my 06 Fxdwgi. Works fine with my stock 1156 bulbs, but weren't bright enough for me. I got me some sylvania 1156 led bulbs today (want to get Radiantz soon) but I installed them and my left side won't come on at all. I put back in my stock bulb and works fine. I put each led bulb on the right side and both work fine. Put the led on the left won't work and I'm having a hard time figuring it out.
any advice is much appreciated
thank you in advance
mikee
Old Nov 13, 2017 | 04:49 AM
grbrown's Avatar
grbrown
LEDs will only work if the polarity is correct. Normal bulbs aren't bothered, so will light up. It is likely the wiring for your left side is reversed, or the Badlands is wired in wrong way around, so check polarity.
Old Nov 13, 2017 | 05:02 AM
Iceman24's Avatar
Iceman24
Also...LEDs draw less power so the one side is good, but other needs load balancer. Either way, it's best to upgrade all in one swoop. I always go w/Custom Dynamics...their products work well & have lifetime warranty.
Old Nov 17, 2017 | 03:58 PM
mjeddy78's Avatar
mjeddy78
6th Gear
reversing the wires did work thanks
Old Nov 17, 2017 | 04:07 PM
grbrown's Avatar
grbrown
Thumbs up
Phew! Thanks for reporting back and well done for fixing it.
Old Nov 17, 2017 | 04:10 PM
mjeddy78's Avatar
mjeddy78
6th Gear
thank you
I meant to respond earlier but got busy...
hey I posted another question
about progressive forks
do you have any knowledge with progressive forks?
Angryman
Apr 29, 2018 05:23 PM
adiddik
Jan 13, 2018 07:19 AM
Racinboy
Electrical/Lighting/Alarm
Jul 6, 2014 11:56 AM
sickboy75
Jul 6, 2014 08:49 AM
mikec
Oct 4, 2006 12:19 AM
