Left Blinker
Old Oct 3, 2006 | 01:42 AM
mikec's Avatar
mikec
Default Left Blinker
Was riding tonight......hit the left blinker and after
about 5 blinks its starts blinking at twice the rate.
Checked bulbs, ok......whats up? Right one not
doing it either.
Old Oct 3, 2006 | 01:58 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Left Blinker
Are BOTH bulbs on the L flashing rapidly???? and in time with the indicator....
Just guessing here but prolly not.....
One of the bulbs could not be seated in the socket correctly, or the socket tail is out of line with the socket.....
If they are both flashing the same speed and brightness, you could have an open in the T/S wiring for the L side....
Electrical over the internet SUXXXXXXXXXXXXXX!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
Old Oct 3, 2006 | 06:36 AM
Sooee's Avatar
Sooee
It is grumbling because there is not enough resistance to work the flasher unit.
Check both bulbs are working, check the wattage of each and make sure one or both are not LED bulbs (you need a load equalizer if both are LED) otherwise you may have a dud flasher unit.
Old Oct 4, 2006 | 12:19 AM
mikec's Avatar
mikec
It ended up being a loose bulb.......feeling kinda
stupid. da!
AussieDog
Sep 6, 2018 12:50 AM
Clavinavi
Electrical/Lighting/Alarm
Jun 17, 2018 02:00 PM
JonnyVegas
Jun 5, 2018 10:51 AM
mjeddy78
General Topics/Tech Tips
Nov 17, 2017 04:10 PM
ScottBrosRacing
Aug 16, 2017 03:11 PM
