Push rod adjustment
Old Jan 28, 2018 | 02:49 PM
Rickity's Avatar
Rickity
Default Push rod adjustment
A lady friend of mine needs a lifter block gasket replaced. 2000 heratige soft tail, She thinks there is a large cam installed not sure of the brand of push rods are. If there is no part # on them. What’s the best way for getting the right adjustment. I understand there is a thread per inch ratio. Do you think that would be a safe way to go. Trying to get it done today. Thanks for the advice. Hydraulic lifter she thinks, Did not want to pull apart til got adjustment ideas.
Old Jan 28, 2018 | 03:44 PM
Taggs's Avatar
Taggs
You could just pop off one pushrod tube cover first to determine if it even has adjustables
Old Jan 28, 2018 | 03:52 PM
Rickity's Avatar
Rickity
They are adjustables took tube loose to see if I could see a part #. They have 24 threads per inch
Old Jan 28, 2018 | 04:05 PM
Pachuco's Avatar
Pachuco
This video explains it. The stuff about finding the right adjustment when you don't know the components starts after 15:00 mins.
Old Jan 28, 2018 | 08:00 PM
bustert's Avatar
bustert
well without knowing what she has, it would be futile to say.
are the straight up hydraulic
are the using the limited lifter travel spacer
are the straight up solid lifter.
the only way to tell for sure is to look, the limited travel you could see how far it will collapse but you must be sure you bled the lifter totally down or remove the retainer and shake out the parts.
as a side note, the spacer will change how a hydraulic cam will work as they have diff profiles from a solid cam.
i run the spacer since i crank the rpms up to 7.5k so i do not need a collapsed lifter. the hd units are 6.8k and pushing it. i also do not need pump up. at cold start, no worries about bled down.
you must put the rod to be adjusted up on the top of the cam and give time for spring pressure to squeeze all of the oil out. then you set it on base and take all the slack out, i use 3 to 3.5 flats (rivera rods 40tpi or .025 per turn) out just enough movement to quite the valve train. once all are done it might take 5 miles of riding for the lifters to quite down and they do make noise. the book gives a better way to set both in/ex at the same time so i suggest you do it that way till you get the feel of it.
straight up hydraulic set on base and lifter pumped up, crank down to give around .010 clearance between plunger top and retainer (preload) to prevent the plunger from knocking out the retainer.
Old Jan 28, 2018 | 08:10 PM
Rickity's Avatar
Rickity
got to love You Tube. Thankx Pachuco.
Dante221
Sep 25, 2018 02:19 AM
Bill wallace
Shovelhead
Aug 25, 2018 11:43 AM
Papa Jack
Engine Mechanical Topics
Aug 5, 2018 11:08 AM
davidsdad
Jan 13, 2012 03:28 PM
JeckyllPhD
Dec 31, 2007 12:24 PM
