Torque Spec?
Old Jan 13, 2012 | 02:04 PM
davidsdad's Avatar
davidsdad
Default Torque Spec?
I am wondering if anyone can help me out?
I am in the process of installing my new Carlini apes on my 2011 Road King. I have to replace the clutch cable with a longer cable. I removed the cover on my transmission to remove the existing clutch cable and install the new cable.
What I need to know is if anyone can give me the torque spec for the bolts that hold the cover on.
"I know, I know, buy the manual!" I plan to, I just haven't got around to it yet.
Thanks..
Old Jan 13, 2012 | 02:16 PM
Ronp42's Avatar
Ronp42
Account Retired
Hope this helps.. I looked at my parts book and the cover you are speaking of is called the Clutch Release cover. That would be 84 to 132 inch lbs. 7 to 11 ft lbs
FASTENER TORQUE VALUE NOTES
6.5 CLUTCH RELEASE COVER, Assembly and
Installation
Clutch cable fitting 90-120
in-lbs 10.2-13.6 Nm
Installation
Clutch release cover screws 84-132
in-lbs 9.5-14.9 Nm
Mainshaft/countershaft nuts 85-95 ft-lbs 115.3-128.8 Nm 6.6 TRANSMISSION ASSEMBLY, Assembly
Neutral switch 120-180
in-lbs 13.6-20.3 Nm 6.8 TRANSMISSION CASE, Installation
Shift drum detent arm fastener 120-150
in-lbs 13.6-17.0 Nm 6.6 TRANSMISSION ASSEMBLY, Assembly
Shift drum lock plate fasteners 57-63
in-lbs 6.4-7.1 Nm 6.6 TRANSMISSION ASSEMBLY, Assembly
Shifter rod lever screw 18-22 ft-lbs 24.4-29.8 Nm 6.8 TRANSMISSION CASE, Assembly
Shifter rod locknut 80-120
in-lbs 9.0-13.6 Nm 6.4 SHIFTER LINKAGE, Shifter Rod
Side door fasteners 13-18 ft-lbs 17.6-24.4 Nm 6.6 TRANSMISSION ASSEMBLY, Installation
Transmission drain plug 14-21 ft-lbs 19.0-28.5 Nm 6.6 TRANSMISSION ASSEMBLY, Installation
Transmission drain plug 14-21 ft-lbs 19.0-28.5 Nm 6.8 TRANSMISSION CASE, Installation
Transmission mounting bolts, final torque 34-39 ft-lbs 46.1-52.9 Nm 6.8 TRANSMISSION CASE, Installation
Transmission mounting bolts, initial 15 ft-lbs 20.3 Nm 6.8 TRANSMISSION CASE, Installation
torque
Transmission top cover 84-132
in-lbs 9.5-14.9 Nm 6.6 TRANSMISSION ASSEMBLY, Installation
VSS fastener 84-132
in-lbs 9.5-14.9 Nm 6.8 TRANSMISSION CASE, Installation
Old Jan 13, 2012 | 02:31 PM
mkguitar's Avatar
mkguitar
btw side door fastener spec has been changed to 23 ft pounds.
locktite too.
the 2 lower bolts that hold the exhaust bracket have been backing off, hence the new spec
mike
Old Jan 13, 2012 | 03:28 PM
davidsdad's Avatar
davidsdad
Ronp42 and mkguitar, thanks for the quick response!!!
fr33thomas
11
Feb 3, 2019 01:38 PM
user 73739084
Dec 21, 2018 11:01 AM
Brethrenchad
Welcome Area Only
22
Sep 26, 2018 06:06 PM
jadev
Jun 18, 2008 09:37 PM
rde
Jan 20, 2008 11:59 PM
