2001 TourGlide
Old Jun 16, 2018 | 12:44 PM
Mitch26's Avatar
Mitch26
Default 2001 TourGlide
Fuel line fitting is leaking. Sprays fuel when you start it up and energize the pump. How do you fix it?
Old Jun 16, 2018 | 06:19 PM
ScottinAZ's Avatar
ScottinAZ
two choices, either change the o-rings inside the fittings (14mmx2mm) or change the fittings on the tank. Some will say the oil drain plug o-ring will work for this, but it didnt with my 2000 ultra. I had to go with a metric sized o-ring in the fitting to stop a slow drip. They MAY have changed the fittings slightly between the Delphi injection (2002+) and the Magneti Marelli (2001 and earlier)
Old Jun 16, 2018 | 09:04 PM
Ron750's Avatar
Ron750
Lots of threads on changing the quick conect o ring. I thought it was a PIA. I had my mechanic put a new quick connect on, and replace the in tank fuel line, which is prone to pinhole leaks. 2003 FLHTCUI100.
Bryce05
EVO
Jan 15, 2018 05:04 PM
sloans4x4
Sep 2, 2015 02:14 PM
Jukebox
Nov 30, 2011 03:53 PM
al baehr
Jul 10, 2011 08:26 PM
mattHD
Apr 28, 2011 08:40 AM
