Brake light issue
Old Aug 26, 2018 | 08:29 AM
pjchops's Avatar
pjchops
Hazards and directionals are a complete separate issue, fix one problem at a time to avoid confusion.
If the brake light stays on when the rear switch is disconnected, there is only one way the lamp is getting power, through the front brake light switch...
But before you have a funeral for the switch, make sure it is not just simply stuck.
I unplugged the rear switch and brake lights still on, the only time when they go out is when I pull the brake relay, I took front switch apart today, it’s not stuck, moves freely, could the switch just have burnt out? Could it be an excused wire in the rear harness under the fender? The front brake switch is $70 and I have to splice it in, that’s a lot of time and money if that’s not the issue...I appreciate your help!! Thanks
Old Aug 26, 2018 | 08:54 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
They are $17 on eBay and mine has lasted longer then original. (May be that I put LED on brake light) The$17 one comes with wireing now that joins outside clamshell. The third hydraulic one I used was a life time AutoZone part.
Get you a $20 AC/DC Volt ohm meter
drsnipes
Dec 3, 2023 01:18 PM
Noshame
Electrical/Lighting/Alarm
Nov 29, 2018 04:04 PM
pjchops
14
Sep 27, 2018 02:40 PM
mrush1130
Sep 22, 2013 10:08 AM
baron310
Oct 18, 2010 08:08 AM
