Engine and Trans swap
Old Dec 19, 2018 | 04:43 PM
Scott Wagner's Avatar
Scott Wagner
2nd Gear
Default Engine and Trans swap
Does anyone know if the twin cam engine and trans from a 2003 Road King will bolt into my 1998 FLHTCUI?
Old Dec 19, 2018 | 09:19 PM
Max Headflow's Avatar
Max Headflow
It will but you will have to lower the rear under-frame cross over or make a custom oil pan. Also IIRC on some of the evos you need to change or modify the front break master cylinder location. John Kitzmiller of Zippers Performance did an Evo.. I've done an after market FXR evo frame an only had to lower the rear cross over.
Old Dec 23, 2018 | 06:43 PM
Mattbastard's Avatar
Mattbastard
Don't forget about the ignition too. Evo's have the cam cover, TC's use the crank position sensor (from those respective years, anyway).
And you typed in FLHTCUI, which implies to me MM fuel injection. If the Road King motor is FI, that's the Delphi system.
firefighterj
Mar 20, 2013 12:48 PM
dirt2race
Jan 5, 2013 08:01 PM
Cajun King
Exhaust System Topics
Mar 6, 2012 06:28 PM
broke c7
EVO
Aug 18, 2008 06:07 PM
munich62
Jun 7, 2007 01:50 PM
