Rotor
Old Feb 5, 2019 | 06:46 AM
Triggerusmvmc's Avatar
Triggerusmvmc
Stage I
Default Rotor
So I’m feeling a pulsing in when braking , i have the extended warranty, first they can’t recreate the problem, not really sure how they couldn’t but that’s not the point. Then they tell me that my rotor is warped but it’s still within “spec” so they don’t consider it a broken part and won’t warranty it. In my opinion any warping that can be felt when braking is a safety hazard.
Old Feb 5, 2019 | 08:34 AM
bustert's Avatar
bustert
https://www.brakeandfrontend.com/warped-rotors-myth/
you need to ask for the dial indicator readings and they should be on the service report. as the article said, uninformed persons will short hand it. after the report is in hand, a second independent check should be made.
look at the rotor for shinny spots or discoloration, these are high spots. sometimes rotors when made can develop hard spots that show up after some use and it is a defect not associated with what the article said, i had this problem a few times on various rotors.
whether or not they say it is acceptable, it should be replaced. you are right, in the wrong situation, braking is compromised. what you might do is ask them to write on the service ticket it is all and good and they will stand behind the evaluation if something happens, if not, demand replacement.
a good source of help is use the BBB. they will write a letter to them with your concern and they have a chance to reply, IT WILL BECOME PUBLIC KNOWLEDGE so any future events will not need a president as their actions are already known via the report. does not cost you anything and you will help the bro coming after you.
chapy6767
2014-2024 Touring Models
Feb 22, 2018 09:47 PM
EasTexUltra12
Oct 27, 2014 07:57 AM
Markk9
Feb 23, 2013 05:31 PM
kings ride
May 31, 2009 07:39 PM
Dalton
May 5, 2007 07:05 PM
