Cam Defect Information
Old Oct 25, 2005 | 01:08 AM
HDF Tech's Avatar
HDF Tech
Default Cam Defect Information
The Engine Build Date Determines the Defect
First let’s see who is affected by this bearing failure and who isn’t.The build date of your engine, (from Milwaukee’s massive Pilgrim Rd. plant) and NOT the assembly date, (which is done in the York Pennsylvania plant), of the motorcycle is the important piece of information to determine whether the old style no good ball bearings are installed in the cam support plate or the new improved roller bearings, (part # 8984), are there. You or your dealer can phone the Factory with two engine serial numbers, the vehicle identification number, (VIN), that your bike is registered with off the left side engine casing at the base of the cylinders and the motor number off the bottom of the right engine case. If your engine was built before Dec. 14 1999 then you have the problem ball bearings. On and after Dec. 14 1999 and the new improved roller bearings with the new cam support plate will have been installed in your engine.Harley’s are built in ½ years not the full yearly production you are probably more familiar with. Each manufacturing year has an early and late production. For example, in general, the early 2000 models will have fewer changes than the later 2000 manufactured bikes. HD introduces many mechanical changes half way through the year to correct problems and for a variety of other reasons. Therefore early 2000 bikes will mechanically mimic late 1999 models while late 2001 bikes will be more similar to early 2001 models.
To speak with a Harley-Davidson customer service representative call (414) 343-4056.
toad6301
Dec 14, 2010 09:22 PM
strtarrow
May 11, 2010 11:55 AM
spiro
EVO
Jan 18, 2009 08:27 PM
Waldo
Exhaust System Topics
Jun 15, 2007 10:46 PM
HDF Tech
Engine Mechanical Topics
Aug 22, 2005 11:01 AM
