Throttle swap to left side
Old Jul 11, 2019 | 08:03 PM
Bradw71019's Avatar
Bradw71019
3rd Gear
Default Throttle swap to left side
Disabled vet looking to swap throttle to left side so I can ride again, any ideas? If I can’t figure this out my riding days are over
Old Jul 11, 2019 | 08:24 PM
YZR's Avatar
YZR
I have no advice but I'm rooting for you!
Someone here will have a solution.
Old Jul 11, 2019 | 08:28 PM
MyFavRk's Avatar
MyFavRk
Good luck to you sir , I hope there is an answer to your question .
Old Jul 11, 2019 | 08:37 PM
chopper_man's Avatar
chopper_man
Give these guys a shout. https://www.ride2guide.com/disabled-rider-aids
Good luck.
Old Jul 11, 2019 | 08:41 PM
dawg's Avatar
dawg
Cable throttle is doable I believe, TBW is a showstopper. Here is a thread about the same issue. https://www.hdforums.com/forum/gener...e-by-wire.html
Old Jul 13, 2019 | 07:03 AM
TomCop's Avatar
TomCop
Look at lowbrow customs , they have throttle controls. Instead of mounting them on the right, you can have them installed on the left. Same for the grips. Good luck, hope it helps.
https://www.lowbrowcustoms.com/motor...der=created_at
Old Jul 13, 2019 | 09:17 AM
bustert's Avatar
bustert
first of all, what machine are you talking about
as far as doable, very high probability, even drive by wire. some wiring will have to jump connectors but that is easy and will be mostly directional stuff.
the biggest issue i see here is if it is drive by wire, the throttle will be reversed evil kenevil style. can you get used to that??
if not, will have to get a custom throttle made.
Old Jul 15, 2019 | 02:53 PM
grbrown's Avatar
grbrown
You are not the first rider on the planet with this challenge! Somewhere there is a solution, waiting for you come across it. Here in the UK we have disable rider charities like NABD who can do wonders for riders with difficulties such as yours, Surely there are vet and other similar organisations in North America? I have in the past encouraged HDF to create a section for riders with a disability, but it hasn't happened, unfortunately.
Old Jul 21, 2019 | 08:35 AM
marcodarq's Avatar
marcodarq
What year and model bike?
M
Old Jul 21, 2019 | 09:15 AM
touchdown204's Avatar
touchdown204
Had a friend his dad was a vet lost his right arm he had a hook for a hand. So everyone called him hook he raced motorcycles, yes throttle was on the left. So its easy to do, just switch everything around, depending on what bike you may have to get longer cables or wires. Then comes the hard part learning how to ride opposite side controls so take your time.
