Mixing different engine ils together
Old Jul 13, 2019 | 12:47 AM
papaharhar's Avatar
papaharhar
Default Mixing different engine ils together
I bought Del Ray engine oil , 20 50 standard for Harley....and I went to repair shop to get more....They told methey dont have the del rey oil in canisters anymore...so he just filled my old container with new oil....
Is it safe to use same 20 50 oil even though it is not del rey?
Old Jul 13, 2019 | 05:43 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Any 20w50 oil can be used, mixing brands is fine.
Old Jul 13, 2019 | 05:48 AM
Jackie Paper's Avatar
Jackie Paper
A rare one... an oil thread virgin?
Old Jul 13, 2019 | 06:12 AM
Dan89FLSTC's Avatar
Dan89FLSTC
I`m guessing that the op is from a part of the world where oil brand choices may not be a simple as where we live.
In some places you gotta take what you can get...
Old Jul 13, 2019 | 06:13 AM
papaharhar's Avatar
papaharhar
yeah exactly.....we even have 20w 50 salad dressing oil......so maybe i will start with that cause it is cheaper
Old Jul 13, 2019 | 06:31 AM
Hoginedgewood's Avatar
Hoginedgewood
Can't mix oil types or disastrous results, Harley used to say you couldn't switch to synthetic. Next thing you know Harley is putting synthetic blend in the high dollar bikes from the factory.
You'll be fine.
Old Jul 13, 2019 | 09:37 AM
bustert's Avatar
bustert
there are several oil stocks. can you mix them??? if in doubt, just change the oil so the machine is majority the same.
if you are doing oil analysis, it does make a diff since your trend is based off a oil sample you supply when setting up. if you switch brands, best to submit new base sample.
oil has come a long way.
Old Jul 14, 2019 | 07:09 PM
Max Headflow's Avatar
Max Headflow
Old Jul 14, 2019 | 07:50 PM
papaharhar's Avatar
papaharhar
next time i go rent a bagger I will use olive oil
Old Jul 21, 2019 | 07:46 PM
Hey Man's Avatar
Hey Man
Except for the synthetics oil is oil. It all come out of the same ground.
Gasman1979
EVO
17
Apr 25, 2015 01:28 PM
itellya
Oil Archive (no new posts)
Jun 30, 2012 07:24 AM
alyaseen
Aug 15, 2010 08:40 AM
tatkin
May 30, 2007 08:31 PM
Bama Rider
Dec 23, 2006 02:54 AM
