High Idle after hot
Old Jul 19, 2019 | 04:44 AM
jpagan721's Avatar
jpagan721
Stage II
Default High Idle after hot
2009 Dyna Superglide, After the bike gets hot, stays around 250 degrees idles very rough, I sprayed the iac with carb cleaner and ran great for a day then went right back to a rough idle. I bought a new IAC but can't get to the rear bolt easily. Am I going in the right direction or should I be looking at another possible cause?
Old Jul 19, 2019 | 07:14 AM
Coverdog's Avatar
Coverdog
I was able to get the rear screw out using a Torx bit and a combination wrench that fit it. You can only turn it a small amount but for me I figured quicker than pulling the tank off to get access. The new IAC did solve my high idle. Cleaning the old one only worked for a very short time. I also noticed the oring fit was very sloppy, I’m guessing from years of heat.
RollingBurn
Apr 13, 2015 06:25 PM
2kz28
Feb 4, 2012 07:35 PM
Neal Perez
Ironhead
87
Feb 8, 2011 06:08 PM
hddee
Shovelhead
Jul 27, 2008 12:05 AM
duff67uk
Exhaust System Topics
Jul 12, 2007 03:33 PM
