High idle
Old Feb 2, 2012 | 06:51 PM
2kz28's Avatar
2kz28
5th Gear
Default High idle
I need some help guys. I have a 2005 road king with a carb. It cranks and idles fine when cold. After riding for a while and the bike is good and hot it idles high. You can shut it off and let it cool down some, about five or ten minutes and it will idle fine again. Any suggestion would be a great help. I'm pretty good with wrench's just new to working on a Harley. Thanks
Old Feb 2, 2012 | 07:32 PM
The Q's Avatar
The Q
Check for air leaks with WD40 or Carb cleaner where the manifold seals to the heads. Had that same problem with my '04 Sportster. Installed some new James Intake seals and cured the problem.
Old Feb 2, 2012 | 08:17 PM
Mikey 1450's Avatar
Mikey 1450
Always set your idle speed with the engine hot. They ( carburator engines) all idle slower when cold and than when hot.
If you set your idle speed too low when hot it will not idle when cold.
Old Feb 2, 2012 | 09:07 PM
Ragtop's Avatar
Ragtop
have you tried adjusting it?
Old Feb 2, 2012 | 10:47 PM
2kz28's Avatar
2kz28
5th Gear
I have not tried to adjust yet. I wanted to do my homework and get some feedback before I start tweaking. I should have mentioned that it is a 95in with 510g cams, se breather kit and se ignition, and vance and hines pipes.Not sure what's been done to carb All mods were done when I bought it. Except for the high idle it runs like a dream. Thanks for the help
Old Feb 2, 2012 | 10:51 PM
2kz28's Avatar
2kz28
5th Gear
Thanks for the help guys
Old Feb 3, 2012 | 12:59 AM
mkguitar's Avatar
mkguitar
Here's some good info on how the carb works, a common mod and how to adjust and tune it.
http://www.nightrider.com/biketech/hd_cv_mods.htm
this is for future reference.
as pointed out above, once you adjust the idle hot, you'll just use the "enricher" for cold starts. the pull out has a knurled tension **** behind it on the mount.
Make sure your idle speed is high enough to get proper oil pressure.
mike
Old Feb 3, 2012 | 02:30 AM
dickey's Avatar
dickey
If you look down in your carb while operating the throttle, you'll see the idle screw move against the stop. With the bike full hot(after about 5-10 miles), turn the screw veeeeery slowly out (loosening, or counter-clockwise) until you get the lope you desire. Make sure the choke is all the way in.
Old Feb 4, 2012 | 07:35 PM
2kz28's Avatar
2kz28
5th Gear
Thanks for all the info. Will let you know what I find
dwatkins
EVO
20
Jan 27, 2021 05:53 AM
RollingBurn
Apr 13, 2015 06:25 PM
Win_Brad
Mar 15, 2008 10:42 PM
duff67uk
Exhaust System Topics
Jul 12, 2007 03:33 PM
70mach1
Jul 14, 2006 01:15 PM
