Wire extensions
Old Oct 21, 2019 | 05:13 AM
Chunker's Avatar
Chunker
Default Wire extensions
This is for a 2019 Heritage Classic 114. I am going to replace the stock handlebar riser with a HD product but I'll need bar wiring extensions. There is virtually no slack in the existing wiring and when I pulled the bars off could only get 1/2" to maybe 1" clearance from the riser. Brake lines and clutch have enough extra to not need longer cables.
I did some research and found a couple videos about handlebar and wiring extensions. All were replacing the bars so that meant removing the stock wiring and pulling new through the bars. Simple enough but in my case I'm not replacing bars, just putting on risers so the stock wiring can remain internal to the bars. Looks like I need to add the extensions to the bottom end which means pulling the bib and tank. Just a bunch of extra work which isn't overly complicated, just time consuming. I can't imagine what the dealership would charge in labor to R&R all those parts.
From what I can tell it seems that if done that way I can disconnect the wiring in the "tank" area, pull up the slack through the conduit and triple tree, install risers and then I can accurately measure how much extension is needed, order and install. OR get ample length extension and route the extra under the tank area. My thoughts are that if the risers come up 1.5", back 1.5" from stock, anything over 3" would work. I have seen 4" and 6" extensions in catalogs so figure either will be enough. I'll need turn signal/switch extensions L and R and TBW extensions, all about the same length.
For those who have done this, does this sound correct???
Thanks.
Old Oct 21, 2019 | 11:38 PM
Old_Bikes's Avatar
Old_Bikes
I found the easy way was to use KST Kustoms wire extensions.
https://www.kstkustoms.com/collectio...resent-touring
Old Oct 27, 2019 | 08:18 AM
Chambeaux's Avatar
Chambeaux
Removing the tank is actually pretty simple. Get some Namz extensions and you'll be fine.
Old Oct 27, 2019 | 09:05 AM
chopper_man's Avatar
chopper_man
Why not just buy new longer cables? Very little difference in price and you'll also not have to worry about the extra connectors. I personally prefer Gorilla Cables out of CA. Fantastic customer service and very reasonably priced. Have used them both for my SGS and a friends RK.
Old Nov 1, 2019 | 09:36 AM
grbrown's Avatar
grbrown
Forget the fact that you are using the same bars - pretend that after you have removed them, they are new and go from there! Follow suggestions above as if you are making a fresh start. Wiring internally with extensions relies on staggering the joins, so you don't get a big bunch of connections in one place. Trying to extend your existing wiring outside the bars will create an ugly sight I suspect. chopper man's suggestion above looks a good one to me....
Old Jan 20, 2020 | 03:57 PM
Harleylife1's Avatar
Harleylife1
Default namz
Go with Namz and you will be good! they have a easy plug and play kit
Old Feb 1, 2020 | 04:05 PM
GodGunsAndBikes's Avatar
GodGunsAndBikes
I don't see a Namz "kit" per se on their website, but I can get 8" extensions for TBW, Turn signals, and Can/Bus wires, and I think that should all work.
Reaper21
Electrical/Lighting/Alarm
Apr 10, 2018 11:59 AM
SSpeeDEMONSS
Mar 13, 2018 08:21 AM
ITGUY
Apr 12, 2013 01:46 PM
Skunky82
Mar 16, 2011 05:37 PM
imboden
Jun 8, 2007 03:47 PM
