Rebuilding a 2000 FXDWG
Old Apr 16, 2020 | 09:59 AM
Thebikerpiper's Avatar
Thebikerpiper
Default Rebuilding a 2000 FXDWG
Hello everyone!
I have a Dyna with 148,000 miles on her and it seems like every time I ride her something falls off, wears out ,breaks or otherwise goes bad. It's time for a rebuild. I've got a factory manual and can follow directions. I also figured YouTube would be a resource. The thing I'm not sure about, is how to know what you replace and what parts tend to last, e.g. a frame vs. a drive belt. So, I thought I'd start by joining this site, introducing myself and seeing what advice the more experienced members had for he as I start this project. I'm thinking about attending MMI next fall, we'll see if I still want to learn after this experience, lol.
Old Apr 16, 2020 | 11:36 AM
98hotrodfatboy's Avatar
98hotrodfatboy
With that kind of mileage the first thing I would do is a compression test and record your numbers. Then because of you stating "every time I ride things fall off" sounds like it vibrates a lot.. What do the plugs look like? Does it need a tune up and or a carb rebuild? How does the clutch feel? Is it all original? Are you having issues with it? If so rip the primary apart and remove the clutch plates and measure your disc's, according to the manual... Might just be able to get away with new fibers and steels. Check the teeth on your compensator, if they're really pointy then time for a new one. How much slack in the primary chain? Does it adjust out easily? You have a very dependable trans (the 5 speed). If the bike wasn't ridden too hard ou should be all right. What about the suspension? Check it all according to the manual to determine if rebuilding the forks are necessary or not. Most likely it'll need a fluid change at minimum. What does the rear belt and pulleys look like. The Kevlar belt will wear any the rear pulley. Are the rounded teeth worn Flat? Does the belt fit the pulley snuggly? Belts usually last 100k miles. I would also test the charging system.. It's all in the book.. I think there's enough here to get you started... Good luck... By the way if you do have to tear down the motor, check the crank run out on the cam side... The TC 88" up to 2003 or 04 were very strong and should be good.. But at 148K, you never know..
Old Apr 16, 2020 | 11:53 AM
Thebikerpiper
One of the reasons for the rebuild is I dropped a valve in the original engine a couple years ago. It was my only mode of transportation. So, I bought another engineer and dropped it in. I want to rebuild the original engine and put it back in the bike. I had the Makuni carb rebuilt by Harley, but it never seemed quite right after, always ran rich. So, want to revisit that. It's become very difficult to shift and thought the transmission may need redone. Even if not, I'm wanting to really learn my bike and I thought rebuilding her would be the basis of a great understanding of my machine. I don't ride like a demon. I generally do shoot 10 over the posted speed limit, but I run long. 7 iron butts in the last four years. Never been sure on how that works the machine?
Old Apr 17, 2020 | 09:35 PM
Max Headflow's Avatar
Max Headflow
With a 148K miles on the bike. Jack up the gas cap and roll a new bike underneith. If you can't afford a new one, find a garage queen with low miles.
Old Apr 18, 2020 | 01:30 AM
Thebikerpiper
Sure, but that wouldn't be my bike, now would it? For some of us the sled is as much a part of the journey, our personal journey as our own DNA. Obviously, your not that kind of rider, which is great! But be observant enough to know when your opinion is going to contribute to the answer being sought, please.
__________________
Old Apr 18, 2020 | 09:33 AM
Max Headflow
__________________
Well you really don't have clue as to what type of rider I am or the fact that I understand your dilemma. There is a time when it's good to move on. A bike with 150,000 miles on it will likely need to be rebuilt from the ground up. Not only do the motor, tranny and clutch need attention, but the steering bearings, forks, brakes, wheels, speedometer, swingarm, petcock, various brackets and mounts need rebuilding. Unless you've been taking care of this stuff, you'll likely need to do most of it. I get the attachment to a bike, I'm not the "buy a new one every other year" guy. I own 7 motorcycles and there is one, I likely won't part with tho I really enjoy them all. Still I regret a number of motorcycles I've sold in the past.
I've got friends that older bike that have been through the same dilemma. One is a lady that had 94 wide glide, with about 130000 miles on it. She rode the crap out of it. I worked on the poor thing, rebuilt everything except for the wheels, rear brakes, motor and tranny. She had the top end redone so at the time the motor and tranny seemed good. The wheels were OK but on the next set tires, the rims should be replaced. She did a ride from So Cal to Yellowstone and back. Next local ride, the bike started smoking. She was attached to bike because it belonged to her late husband. A couple of us finally convinced here to buy a new heritage. She did an gave the bike to a nephew, and she found a new bike to love.
Another bud owns a 61 pan. It has about 360000 mile on it. Over 100000 on the last motor, He finally bought a used 08 Ultra and has been happy with it. He uses it mostly now while but still uses the pan. He's rebuilt it 1/2 dozen times.
If you want to keep the bike, keep it but get another bike. You will end up spending more rebuilding the old bike than buying a low miles used one for sure.
Thebikerpiper
Welcome Area Only
23
Apr 21, 2020 11:27 PM
kato14709
Feb 15, 2013 09:35 AM
joemoy29
Mar 10, 2011 08:14 AM
mayfiebl
Apr 2, 2008 03:06 PM
morespl
Feb 25, 2006 07:09 PM
