Help please..throttle cable
Old May 24, 2020 | 02:39 PM
Hlgsn1's Avatar
Hlgsn1
Can't remember if they are different....but check lengths and make sure you have the throttle cable and the return cable in the right holes...
check and make sure your cable is in the groove on you throttle grip. Not off the groove causing some slack.
Long time ago i had mine apart was a bit of a pain to get it back together.
just throwing things out here....if you back off/tighten up the return cable it should affect the throttle cable. Maybe one is set to tight to let the other one do its thing.
Old May 24, 2020 | 02:44 PM
mstrlucky74's Avatar
mstrlucky74
Thank you
Old May 24, 2020 | 02:46 PM
Hlgsn1's Avatar
Hlgsn1
never give up....it is good to learn.
Old May 24, 2020 | 05:28 PM
mstrlucky74
I have 14-in ape hangers does anyone know what length cables I should have? Thank you
mstrlucky74
May 17, 2020 02:59 PM
mstrlucky74
Oct 4, 2019 05:38 PM
Robmayas
May 12, 2013 11:55 PM
Road Star
Jan 8, 2013 11:10 PM
Boz
Mar 14, 2010 04:21 PM
