Loctite
Old Aug 28, 2020 | 05:08 PM
CrBear's Avatar
CrBear
You don't carry it in your bag ???
It should always be there with tie wraps, duct tape, and a shovel..
Old Aug 28, 2020 | 05:37 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If you get the replacement bolt from the dealer, it will have the proper locking compound on it.
Blue loctite is all that is needed on a standard bolt (grade 8 of course).
Don`t use a stainless bolt, you want to be able to put some good torque on it.
As nomadmax said, this is an item you want to check periodically along with the critical fasteners.
Also check torque on the bolt that holds the shift lever at the transmission.
Joe from So Cal
Aug 6, 2021 01:39 PM
toxicstang99
Apr 4, 2020 09:01 PM
tenn.vol.
Aug 26, 2016 07:02 AM
Bmatt
Apr 5, 2015 10:09 PM
jfsgb
Shovelhead
11
Jul 4, 2012 05:30 AM
